Check Engine light Question? True or False? - Defender Source
Old April 5th, 2009, 10:39 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
O.k. I keep throwing a p1317 code, which says rough road fault. I have took the sensors out cleaned them. But I clear the code and within hours there is another fault. The real Question here is if it throws a rough road fault does it go into default mode? or is that just for engine codes? I have been told anytime it throws a code it goes into default mode. True or false?
check engine light, engine, ht
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Replaced passenger cat and now I get check engine light shawnpalmer Defender Technical Discussions 35 July 17th, 2008 10:14 AM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
