Check Engine Light On - Defender Source
Old October 6th, 2004, 08:15 PM
david_jackson
Dave Jackson
97 Defender 90 SW
Hello
The check engine light came on and stayed on this morning on my '97 SW. The truck seems to run fine. Any thoughts on diagnostics/repairs I can do myself? I don't have an OBDII code reader.
Thanks! Dave
Dave
Old October 6th, 2004, 08:21 PM
milage?
Old October 6th, 2004, 08:39 PM
david_jackson
Dave Jackson
97 Defender 90 SW
About 41k miles on the clock.
Dave
Old October 6th, 2004, 08:45 PM
Checker / Kragen / Shuck will lend you a code reader for free (you may have to leave a deposit) and will tell you what to do to fix it. Who says nothing in life is free?
Old October 6th, 2004, 09:24 PM
ronward's Avatar
ronward
Redsrover
None - sadly
If she's still running fine, probably an 02 sensor.
Old October 7th, 2004, 12:23 AM
David Jackson
Dave Jackson
'97 Defender SW
Ron, Dave
Those are great suggestions. I suspect it's an O2 sensor too. I just had one replaced a couple of weeks ago. I'll try Kragen and maybe AutoZone to borrow their OBDII reader.
Thanks. Dave
Old October 7th, 2004, 01:37 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Check the engine, I think thats what it means. On a similar note, if my wherlydo is affecting my whatcha and making it make glubba glubba sounds coming from the back of the thingy, what would you all recommend? If it helps, the truck has been driven before, both at night, and in the day.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 7th, 2004, 08:08 AM
Originally Posted by David Jackson
Ron, Dave
Thanks. Dave
Dave J. check the code and find out what it is, then reset the ECU and wait for it to happen again before replacing parts.
Dave since it is happening at both night and day I would say that 2 of your sparkplugs are missing and the coil on your TDI is bad. Try adding sparkplug gap filler to your ECU.
Old October 7th, 2004, 11:59 AM
david_jackson
Dave Jackson
97 Defender 90 SW
Thanks Mike,
I'll definitely try that.
I assume that Kragen etc. will be able to tell me what the codes mean????. Anyone know of where I can find a list of codes and their meaning for my '97 D90?
Thanks as always! Dave.
Dave
Old October 7th, 2004, 12:48 PM
artm
Arthur Maravelis
97 SW
Jeez! Ever hear of searching before asking?
I have often used ACME Premium Spark Plug Gap Filler with excellent results! In fact, I have overgapped ALL my spark plugs from the Corolla to the TR6 by about 1/4-inch and then filled in with ACME to the precise gap called for.
Be sure to get their Premium Jig. Makes a damn easy job of applying the filler. Fully digital controls - just enter the desired gap and you're there in no time! Of course, you can do it manually but it's a bit of work.
Old October 7th, 2004, 12:49 PM
www.d-90.com/forum/showthread.php?t=3418 there is your fault code stuff.
Old October 7th, 2004, 01:18 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
I picked up an OBII reader for about $100, so I can check and clear them anytime. 'seems like a good investment, since it can be used with any car from '96-on.
It could be lots of things. Mine has been throwing a bad speed sensor code every once in a while, that I haven't gotten around to fixing.
Old October 8th, 2004, 12:35 PM
david_jackson
Dave Jackson
97 Defender 90 SW
Thanks everyone for the help.
Borrowed the OBDII reader from AutoZone and read code P1193 - O2 sensor heater circuit open downstream. My shop replaced an O2 sensor a few weeks ago after reading this same code. I cleared the code, and I'll wait to see if the check engine light comes on again. Will also call the shop.
Thanks again. Dave.
Dave
Old October 8th, 2004, 01:22 PM
No problem, glad I could help out a fellow D-90er.
Old October 8th, 2004, 01:37 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
You have 4 O2 sensors in a '97. 1 ahead of, and 1 behind, each cat converter. That's a code for one of the "downstream" (after the Cat) sensors. Maybe the dealer replaced another one; are you usre it's the same code?
Old October 8th, 2004, 02:17 PM
david_jackson
Dave Jackson
97 Defender 90 SW
Hello,
Definitely the same code as before; it's written on the repair records. It's also easy to see which of the two sensors (behind the cats) was replaced. So, I'll wait 'till the check engine light comes on again and take it back to the shop. Payed about $240 (ouch!) for the sensor last time.
Thanks. Dave.
Dave
Old October 8th, 2004, 03:08 PM
artm
Arthur Maravelis
97 SW
www.oxygensensors.com
part#: 250-24883 price 94.99
Auto Medic Supply <partsdoc@automedicsupply.com>
This is a universal requiring you to splice into the wires. VERY easy installation. One year warranty.
Old October 8th, 2004, 05:07 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
They also have an exact replacement available for $109.99
Old October 11th, 2004, 03:49 PM
david_jackson
Dave Jackson
97 Defender 90 SW
Good suggestion. I bought a couple of O2 sensors from these guys on Friday. Good to have spares. Dave.
Dave
check engine light, engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
