check engine light on - Defender Source
Old April 27th, 2010, 11:50 AM
matansas
jon lyons
97 AA Convertible
Ok fixed the gauge lights, tail lights and now check engine light on steady. 50 miles from a LR dealer. Book says if its not flashing don't panic. Can i wait or someone said disconnect bateery and see if it resets. I of course check gas cap.
Old April 27th, 2010, 11:57 AM
Go to autozone and buy a $30 OBD II code reader and see what it is. Snice you have a 1997, that will read the code and you can google what the code means. John Robison Service has a list of them online.
Ron
Old April 27th, 2010, 11:59 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
If it's a '97 disconnecting the battery won't do it. You'll have to have the code(s) read. Any local auto parts store will usually read them for you free of charge.
EDIT: What Ron said
Old April 27th, 2010, 12:23 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
I don't panic even when it's flashing. Goes solid after 10-15 seconds. Usually the rough road sensor.
-Ren Ching
Old April 27th, 2010, 12:32 PM
You can get it read for free at most places, but you want to buy your own scanner as they are cheap. Make sure to get a scanner than can clear and not just read, codes.
Old April 27th, 2010, 02:28 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Second that.
The local Autozone is convinced that it is against Texas law to erase the code. Drove me crazy enough just to buy my own scanner. They dont seem to understand that erasing the code doesnt fix the problem and the light will just come right back if it is a real problem.
Old April 27th, 2010, 02:29 PM
matansas
jon lyons
97 AA Convertible
thanks
Rig sleeping in Ma for a few weeks, but i will pick up scanner and hope for the best
check engine light, engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
