Check Engine Light/Fault Display Issues - Defender Source
Old August 30th, 2015, 06:10 PM
D90884's Avatar
D90884
Jon
1994 Defender 90 #884
I have an issue with my CEL and Fault display (94 NAS with 14CUX). I bought my truck last year and have had ongoing issues with the CEL coming on. The fault display has never worked. I have gone through much of the wiring and even replaced the warning lamp cluster, replaced the engine warning check light unit behind the dash (AMR 2041), bought a second hand fault display that I was told worked in its last application and tested the wiring from the ECU to the fault display. I have 12 volts at the brown/orange wire to the fault display unit and a good ground at the black/slate wire. No voltage readings at the pink and brown/pink wires but the CEL is on. I have cleared the CEL by unplugging the 14CUX control unit but the CEL comes right back on again when starting the truck the next time so I know something is up. Does anyone have any suggestions? Thanks in advance, really stuck with this one. Truck runs well but I would like to figure out what the cause is.
Old August 30th, 2015, 07:42 PM
Google rover gauge.
You know the CEL comes on at startup and then goes out? Does yours stay on?
Old August 30th, 2015, 08:12 PM
D90884's Avatar
D90884
Jon
Thanks, great suggestion on the rovergauge software. Is the best source for the interface cable still to build it yourself or are these available from a source now? The developers website readme file says it needs to be built.
Also yes my CEL stays on continuously.
Thanks.
Old August 30th, 2015, 10:09 PM
Thanks, great suggestion on the rovergauge software. Is the best source for the interface cable still to build it yourself or are these available from a source now? The developers website readme file says it needs to be built. Also yes my CEL stays on continuously. Thanks.
I have some of the parts to make them. Pm your address and I'll send you the bits.
Old August 31st, 2015, 05:35 AM
D90884's Avatar
D90884
Jon
Thanks! PM sent.
Engine Ticking / Oil Light / Fault Codes minch77 Defender Technical Discussions 33 October 4th, 2017 09:14 PM
The 97 odometer display issue ECR Defender Technical Discussions 26 April 7th, 2011 01:11 PM
diagnostic display Overland90 Defender Technical Discussions 3 March 12th, 2009 05:50 PM
Does a 4.2ECU work with a diagnostic display? Hans Defender Technical Discussions 1 February 14th, 2009 11:54 AM
Pulse Generator - LED Odometer Display GYM Defender Technical Discussions 7 November 26th, 2008 11:31 AM
