Check Engine light, code 17 - Defender Source
Old March 16th, 2004, 06:51 PM
mchombeau
Mike Chombeau
94 D90 ST
My check engine light comes on occasionally. The first time it came on and stayed on, I checked the display and it had a 17, which if for the Throttle potentiometer. The information I found said: Usually indicates a bad throttle position sensor. Does anyone have any ideas where this is or how to fix it? The truck is running and idling fine.
Mike.
Old March 17th, 2004, 09:55 AM
I Post this every other week.
http://www.rangie.com/articles_topic...at=6&subCat=26
You should find what you are looking for here, I would guess that the problem is from a dirty connection as it is comes on occasionally.
Old March 17th, 2004, 12:28 PM
Toddco's Avatar
Toddco
Todd Klueger
1995 Defender 90
WELLS TPS4127 $59.99 Autozone. This part is an orgianl land rover Throttle postion Sensor that comes in a land rover package. Works on the 3.9.
Old March 17th, 2004, 06:12 PM
mchombeau
Mike Chombeau
94 D90 ST
I didn't think about looking in my Range Rover Manual. I'll look there as well.
check engine light, engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
» Defender Registry
Oink
Akitatw4
D90
95beluga
Add your Defender
