Check engine light and code P1176 - Defender Source
Old September 29th, 2005, 09:24 PM
wingnut
Scott Launer
97 D-90 SW
I have a 97 SW that is getting a P1176 error code fairly frequently. The check engine light comes on and then will go out after a few days. In another day or two the check engine light comes back on with P1176. Every now and then it idles a bit rough. Other times it hesitates a bit at 2500-3000 RPM. 91K miles on the clock.
A Google search yields this ---> Maximum Positive FMFR Correction Fault.
Anyone have an idea what the bloody hell that means and what may be causing this code?
Thanks!
Old September 29th, 2005, 09:36 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
FMFR is Fuel Mass Flow Rate...it means that the ECU cannot correct the fuelling to it's liking within it's allowable parameters. Based on my experience, I would check the basics like fuel pressure and air filter, and the connection at the airflow meter. I would look at the airflow meter connector...it should have gold pins. Some of them were mismanufactured and corrected under warranty with a replacement sub harnass. I would trace the airflow meter wiring back and make sure that if the sub harnass was installed that the wire joints are ok...i.e. not put together with crappy butt connectors. You may ultimately find that the MAFS is sending a faulty signal and tripping the light. You can test by substitution if you have a friend with a similar vehicle...swap the MAFS and see if the problem follows the part.
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 30th, 2005, 11:26 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Mind you that "similar Vehicle" could be a Disco 1 '96-99 For your '97 90 Or a GEMS RR.
This brings up something that's been bugging me.
Maximum Postive correction fault? Not enough fuel?
Maximum Negative corrction fault? Too much fuel?
Or vice versa?
Keith
Big, Red and ... aaa Red..
Old September 30th, 2005, 11:41 AM
RoverChic's Avatar
RoverChic
D-90 Source P.I.
02 D2, 13 E350 AMG, 11 Ford F350
Scott- I used to get this on my 1998 D1. I cleaned the MAFS (with electrical contact cleaner), cleared the code and it never re-appeared. I have also been told it can be due to faulty 02 sensors, most likely the ones Upstream the Cats. Hope that helps.
I bought the diamonds myself so I would not have to say thank you to anyone.
Old October 3rd, 2005, 08:31 PM
wingnut
Scott Launer
97 D-90 SW
cool. Thanks for the tips. I'll give those things a once over see if it helps.
Old October 7th, 2005, 07:41 PM
wingnut
Scott Launer
97 D-90 SW
Thumbs up
Well...the light has been out for a couple days now. I basically pulled all of the intake plumbing out and cleaned it all up really well...including the MAF sensor. What I think fixed it was the connection of the updated wiring harness to the MAFS. After removing (seemingly)a mile of electrical tape, i got to the butt connectors. The one for the scrawny little blue wire pulled apart while removing the tape. I removed all three butt connectors, soldered the harness together, and covered it with heat shrink and a mile of electrical tape.
Its idling smooth again and no hesitation between 2500 and 3000 RPM. Time will tell if the P1176 gremlin is gone for good...
Thanks again for the tips!
check engine light, engine, ht
RED Check Engine Light Flagg Defender Technical Discussions 38 July 2nd, 2011 09:31 AM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check Engine Light On david_jackson Defender Technical Discussions 18 October 11th, 2004 03:49 PM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
