Check Engine Light after I was screwing around with fuses... - Defender Source
Old April 1st, 2004, 02:52 PM
P1CR
Mazen Fawaz
97' D90 SW, Arles Blue
Unhappy Check Engine Light after I was screwing around with fuses...
I was playing around with fuses while the car was running. I just replaced the wiper motor and ws trying to change it's fuse when I kept on pulling the wrong one.
Check engine light came on, and will not turn off. I disconnected the battery for an hour or so. No luck.
Any help?
Maz
97' D-90 SW
Arles Blue
Old April 1st, 2004, 03:20 PM
Reset the ECU. If the light comes on after that you may have pulled a wire or lessened a connection.
Old April 1st, 2004, 03:44 PM
P1CR
Mazen Fawaz
How do I reset the ECU??
Maz
97' D-90 SW
Arles Blue
Old April 1st, 2004, 04:56 PM
http://www.defendersource.com/faq/En...lt.html#Lights
check engine light, engine, ht, wing
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
