Check Engine Light - Page 2 - Defender Source
Old August 7th, 2006, 02:13 PM
artm
Arthur Maravelis
97 SW
My handheld reader displays P3999 and I'm pretty sure it means no codes set. It's been a while since I've hooked it up.
Old August 7th, 2006, 02:26 PM
steved90
steven melnyk
i am having the same issue right now and am getting the p1193 code.
i have an obd2 scanner and cleared the coeds but as soon as i restart the Check engine light pops back on.
i need to get that light off to get my state sticker, is there another way beside replacing the O2 sensor? i don't have the extra cash to replace that right now and i need to get it registered. any suggestions?
Old August 7th, 2006, 02:45 PM
boatbuggy@aol.com sells O2 for a little over $100.
Humm,
Check the wiring on the one O2. I have seen them melt and short. Since it is open circuit that is possible (or it is just a false code for whatever reason).
on for one sec. and then off is the correct self test.
Old August 7th, 2006, 04:03 PM
steved90
steven melnyk
ron could you be so kind as to tell me where to find the o2 sensor??
there are four correct?
Old August 7th, 2006, 10:05 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Crawl under the truck when it has cooled off and feel up and around the cats there are 4.
2 each side.
there are 2 up front near where the down pipes bends and 2 more about a foot back
Old August 7th, 2006, 10:09 PM
steved90
steven melnyk
thanks ron
i will do that tomorrow!
i did get the codes to finally clear and passed emissions this afternoon.
check engine light, engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
» Defender Registry
Clank
HalweJakkals
90
clb1994
Add your Defender
