Check Engine Light - Defender Source
Old November 14th, 2015, 07:45 PM
NAS Addict's Avatar
NAS Addict
Jeff
95 D90 ST #2617
Check Engine Light
The check engine light has been on and off (mostly on) for years. When it first came on a meeting of the minds (to include a friend who is a rover master mechanic) did some tests and figured it was a bad O2 sensor. Performance was not affected and I have no emissions inspections so it was left.
I changed the old fuel filter today and the light went off and has stayed off. Does this make sense of just a coincidence? Is the fuel filter linked to the check engine light in any way?
Thanks for the opinions.
Old November 14th, 2015, 08:16 PM
Ah where to start with the CEL...
to answer your direct question.. Maybe low fuel pressure could starve the engine and trigger a CEL.. do you know which code it was throwing - you can check via the reader under the passenger side seat btw..
44 is left (drivers) and 45 is passenger side.
if you did not reset the battery then it should still show..
there is a process for reading all the codes as well..
having a code will effect your fuel economy..
95' D90 - daily driver..
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check Engine Light On david_jackson Defender Technical Discussions 18 October 11th, 2004 03:49 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
Check Engine Light after I was screwing around with fuses... P1CR Defender Technical Discussions 3 April 1st, 2004 04:56 PM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
