Check Engine light - Defender Source
Old February 18th, 2005, 08:32 PM
jracenstein
Jeffrey Racenstein
Check Engine light
My check engine light just came on but truck is running fine. Any suggestions as to what it may be before I have to take it into shop to check it out.
thnks
Old February 18th, 2005, 09:34 PM
Chaucer
Will
93 110 | 97 90
Try to pull the code with a code reader. How many miles? Could be an O2 sensor...
Old February 18th, 2005, 10:23 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
ignore it, that's what I'm doing!
is it the check engine or service engine light?
"It's not a Jeep"
Old February 19th, 2005, 07:09 AM
jracenstein
Jeffrey Racenstein
It has 50k miles and it is the check engine light
Old February 19th, 2005, 08:25 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Mine has been on for three years..... I was told that the only time you really need to heed it is when it is flashing, then call AAA!
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old February 19th, 2005, 08:51 AM
JBurt's Avatar
JBurt
Jesse McCoy
What I did:
Check under your seat (Passenger) and see what the number is. Then reference that to fourfold.org and see if it's something major or something you can ignore. Next try and find that site that explains how to reset it on your own (it's a magazine article in something I think) or just live with it on.
Good luck!
"It's not a Jeep"
Old February 19th, 2005, 10:37 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
I'm with Jesse & Burke...
Mine's been on since 02/02/02 when I drove my D-baby back from Miami, it came on... I've changed everything that has to do with the 'code' that it shot out, but it still came on... Runs great.
Nicholas
Old February 19th, 2005, 01:35 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
What do you mean... It's not supposed to be on?
Old February 19th, 2005, 05:11 PM
dameek
Dennis Meek
95 D90 #2826 Bought New
Next time you have your dash apart reset the check engine module yourself. Land Rover wanted about $150 to reset it, so I went home, took the dash off and reset it with a paperclip. It is a small brown module with a sticker over the hole you need to insert the paperclip into. I just got tired of it lit all the time.
Dennis Meek
Old February 19th, 2005, 06:56 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
What year truck is it? 94 and 95 have a display for the engine code up under the cardboard panels that the passenger is always kicking. It's the box all the way on the right labled "Diagnostic Display", inside is an LCD that shows the number of the engine code. Oddly enough, the box is sealed and you need to take the cover off to see the code (sometimes you can see it through the housing if it's not too bright out)
97 Defenders have the box located under the passenger seat.
On the 94/95 versions, it only monitors the fuel injection system. Normally it means a bad sensor somewhere. 97 trucks it also monitors the ignition.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 19th, 2005, 08:09 PM
JBurt's Avatar
JBurt
Jesse McCoy
In my '95 it's under the passenger's seat as well, but that may be something the PO did to it.
"It's not a Jeep"
Old February 19th, 2005, 08:56 PM
dameek
Dennis Meek
It's under the seat on 95's. Also, it comes on around 50K and 100K.
Old February 20th, 2005, 06:34 PM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Talking
Don't you love these damned things?
Old February 22nd, 2005, 05:22 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
thnks
'can't help you without the model year. Different years used different systems.
Nope. 97's use OBDII. There's an OBDII connector behind the transfer case lever.
Dennis Meek
You're confusing "check engine" with "service engine". "service engine is just on a 85K mile timer. "check engine" is set when a code is stored by the OBD system, and indicates something out-of-spec was detected.
Old February 22nd, 2005, 05:32 PM
You misread it - its actually a "change engine light."
It means its time to convert to Tdi...
engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
