Check engine light - Page 2 - Defender Source
Old January 25th, 2011, 09:33 PM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
where can you read the codes on a 94?
That is why it is called a short cut. If it was easy it would just be "the way."
Old January 26th, 2011, 01:10 AM
tdn's Avatar
tdn
Troy Norton
'94 D90
It has the little black box on passenger side footwell up against fender. To right of AC. It's hidden behind a plastic panel next to the door.
Old January 26th, 2011, 08:48 AM
jhhorse
joe heins
1995 defender 90
I have had the CEL come on for an O2 sensor before and just cleaned all the gunk out of vacuum and air intake system, that fixed the issue. O2 sensors just catch the brunt of everything that could possibly be wrong upstream.
Old February 25th, 2011, 02:20 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
So just to be clear what side is left and right? Left= drivers?
I was wondering if it's opposite to that because the UK drivers is the other side...?
Or am i thinking about this too much lol.
Pete
Old February 25th, 2011, 04:29 PM
in the UK we use the terms near-side and off-side ( not just in football ( soccer))
So near side would be the side of the car nearest the curb, which in a right hand drive car is the left hand side.
The near-side and off-Side swap when you consider LHD and RHD cars ....
What you need to ask is ... is the Left side when facing the truck of facing the direction the truck is facing???
Hope that helps!! ;-)
Old February 25th, 2011, 11:44 PM
Broncoduecer
peter
D90
Um kind of cryptic, lol.
Left or right would have been easier and then convert, but like you mentioned orientation to the engine bay is what the concern is. So still unanswered? Unless a code manual in the UK states near or far side with regards to the lambda sensors...
Pete
Old February 26th, 2011, 10:01 PM
jhhorse
joe heins
1995 defender 90
as I understand, left side (bank) is drivers side NAS, right side (bank) is passenger side
Old February 26th, 2011, 10:18 PM
Broncoduecer
peter
D90
Cool. Thanks jhhorse.
check engine light, engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
Check Engine light jracenstein Defender Technical Discussions 14 February 22nd, 2005 05:32 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
