check engine light - Defender Source
Old May 14th, 2010, 07:31 PM
matansas
jon lyons
97 AA Convertible
check engine light
so i bought the meter, plugged it in and it said one code P1317. Great checked every list and can't find it. Any ideas?
Old May 14th, 2010, 08:11 PM
Google is your friend
http://www.obd-codes.com/trouble_codes/landrover/
ABS Rough Road Line Low Fault
Do 97's have ABS? I'd get your brakes checked, but you could clear it and see if it comes back. You might have triggered it accidental driving on a washboard road or something?
Old May 14th, 2010, 08:20 PM
GYM's Avatar
GYM
Gary
97 SW
Originally Posted by cgalpin View Post
Do 97's have ABS?
Nope.
Old May 14th, 2010, 08:42 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
Just reset it using the reader. It happens to me occasionally. You can try to clean/re-seat the sensor but usually erasing the codes makes it go away. From what I understand it's a bull sheeeot sensor that shouldn't really be used on D90s because of the lack of ABS. There are a number of posts about that code on this forum.
I reset mine about a month ago and I haven't seen it return since.
Old May 14th, 2010, 09:02 PM
Didn't think so. Reset and forget!
Old May 14th, 2010, 09:53 PM
Reset. If it comes back search as there are a few common things that cause it.
Ron
Old May 14th, 2010, 10:36 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
THe 97s have the sensor for the ABS if that doesn't clear it you may need to push the button on the little box in the tunnel. a real pain to get to. I had a shop that had to do this to my truck way back before I knew what to do, charged me like $75 to push a button.
Old May 15th, 2010, 06:06 AM
matansas
jon lyons
97 AA Convertible
ok thanks heading out to barn to reset. I will keep you guys posted.
check engine light, engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
