check engine light - Defender Source
Old December 19th, 2009, 12:44 PM
41gpaws
Adison Colin
1995
check engine light
I was driving my 94 yesterday and after 30 minutes on the road the check engine light came on and about 5 minutes later the truck had no power, I could only go 30 mph. Five minutes later she went back to normal but my check engine light is still on, what should I do?
Old December 19th, 2009, 12:51 PM
Time for new oxygen sensors. The no power thing is called "limp home" mode. The ECM thinks there is a major dump of the input sensors, so rather than actually deal with it it shuts down. Apparently it was able to reconnect with whatever sensor failed and was able to operate again in normal fashion. Take it to a place that will read the error codes and it will point out the particulars.
Old December 19th, 2009, 12:58 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Dig around under the cardboard in front of the passengers feet where the computer is, and there will be a brown box labled "Land rover diagnostic display". When the truck is on, you should be able to see a 2 digit number on there which is the trouble code you need. If it's 44 or 45, those are the O2 sensor codes. Best to do them in pairs if you have to replace them.
Best price for oxygen sensors are Standard Motor Products # SG130, right now rock auto has them listed at $45 each.
If the number is something else, let us know and we can dig further.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 19th, 2009, 01:27 PM
41gpaws
Adison Colin
1995
I will go check and keep you posted.
I just located the box but I don't see anything displayed, does anybody have a picture of where I would see the display? colshlby65@aol.com
Old December 19th, 2009, 04:40 PM
41gpaws
Adison Colin
1995
The check engine light went away, do I have to wait for it to come back before I can check the diagnostic box for a code? Right now I don't see any codes.
Old December 19th, 2009, 05:33 PM
Hans's Avatar
Hans
Hans Haase
Correct, it will only display the code when the check engine light is active. It doesn't have a long term memory.
-Hans
My oil line fix
check engine light, engine, ht
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
