Check engine light 120k miles - Defender Source
Old February 26th, 2015, 08:46 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
I searched the forum but haven't found anything on this yet. I just started my car after about 2 weeks in the cold here in NH and it just turned 120k. Started right up but check engine light stayed on. Drove it for 20 mins, warmed up nice. Shut it down for a few and started back up and check engine light is still on.
Car runs perfect. Curious as I'm new to LR and Defenders does the NAS defenders use the check engine light to tell you it needs a major service? This is the first time I started it since it turned 120k miles. The miles are now 120,063. It's a 1994 NAS ST.
Or is it just one of several electric/light gremlins I am experiencing? I don't have access to a code reader.
Will
Old February 26th, 2015, 09:17 PM
Check the code reader in the passenger footwell and report back with the number it is displaying.
Old February 26th, 2015, 09:48 PM
the rover shop
shayne young
Or disconnect the battery for 20 seconds...that will clear the code..if it comes back on then you have a fault..
Old February 26th, 2015, 11:02 PM
61rover's Avatar
61rover
John Crouse
Lol. My check engine light comes on about every six months. I flip the battery disconnect for a few minutes and it goes away. Been doing this for years.
Old February 26th, 2015, 11:21 PM
wmatos1001's Avatar
wmatos1001
William
Thank you everyone. Shows how little I know. Didn't know there was a code reader in the passenger footwell. I will check and disconnect battery as well.
Appreciate the quick responses. Thanks again.
Old February 27th, 2015, 07:37 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by wmatos1001 View Post
Thank you everyone. Shows how little I know. Didn't know there was a code reader in the passenger footwell. I will check and disconnect battery as well. Appreciate the quick responses. Thanks again.
You can get a code reader at most auto parts shops. A simple one is all you probably need. It will come in handy. You may have a little water in the tank which you can treat with a fuel additive. Probably not a bad idea anyway. When you leave it sitting that long you should have the tank full to decrease this problem.
Clay
Old February 27th, 2015, 07:49 AM
Clay he has a pre-OBD vee-hickle.
I'm gonna go out on a limb here and say the truck needs oxygen sensors.
Old February 27th, 2015, 08:02 AM
1of40's Avatar
1of40
1of40
Originally Posted by o2batsea View Post
Clay he has a pre-OBD vee-hickle. I'm gonna go out on a limb here and say the truck needs oxygen sensors.
damn, I'm getting old. I read 97. My bad guys.
Old February 27th, 2015, 11:33 AM
D90884's Avatar
D90884
Jon
1994 Defender 90 #884
Will,
My truck has the same issue. My display in the passenger footwell shows no numbers but it may not be working. Replacing the O2 sensors seems to be the consensus on fixing it, but the CEL does sometimes shut on or off when I apply the parking brake so it could be crossed wiring somewhere... If you figure out yours it would be great to know what activated it. I am at 126k so mileage is similar.
check engine light, engine, ht
97 D90 check engine light - on now off? Eric_S Defender Technical Discussions 3 January 28th, 2005 10:17 AM
Check Engine Light On david_jackson Defender Technical Discussions 18 October 11th, 2004 03:49 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
Check Engine Light after I was screwing around with fuses... P1CR Defender Technical Discussions 3 April 1st, 2004 04:56 PM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
