Check engine code P1179 - Defender Source
Old June 30th, 2015, 10:36 AM
quick968's Avatar
quick968
Mikey
97 Defender 90
Hi guys,
Any idea what P1179 Maximum Negative AMFR is referring to? And more importantly how to prevent it reoccurring?
Thx
Mikey
Old July 1st, 2015, 10:37 PM
quick968's Avatar
quick968
Mikey
97 Defender 90
A search, (yeah I know) revealed that P1179 is usually caused by a clogged fuel filter. What appears to have been the original AC Delco filter was indeed so plugged I could barely blow air through, it's a wonder the engine ran at all. I installed a fresh Fram filter with zero flow resistance and not surprisingly the surge of fuel flow and pressure flipped the code to P1180 Maximum Positive AMFR. I let it settle down, drove a few miles, stopped and restarted, then cleared the code. Presto, no reappearance. Lesson learned, replace that fuel filter regularly.
Cheers
Mikey
Old July 2nd, 2015, 06:50 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Congrats! When I think about it the filters are cheap and easy to get to probably for a reason and should probably be changed more often.
engine
Check Engine Code 45 The Wizard Defender Technical Discussions 2 July 2nd, 2010 10:28 AM
Code P1179 Purge Valve ? ERICZZ Defender Technical Discussions 3 September 22nd, 2009 04:20 PM
P1179 Fault Code nmc Defender Technical Discussions 2 June 22nd, 2007 10:59 AM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
