Check Engine Code 45 - Defender Source
Old July 1st, 2010, 08:43 AM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
I was finally able to find the box that displays check engine codes when the check engine light comes on. It is displaying 45 which my source says means "Lambia senor B - right bank". So, in practical terms, what does this mean? Do I have to run to the mechanic today on my lunch hour and get it fixed or can I wait until next week?
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old July 1st, 2010, 09:10 AM
It's the O2 sensor. Clear the code and see if it comes back before worrying about it. To clear the code, disconnect the ECU, turn the key to the run position for a few seconds, then reconnect the ECU. You will get a 02 code at first start which says you disconnected the ECU.
Old July 2nd, 2010, 10:28 AM
read's Avatar
read
Read Kerlin
'94 w/ POE HT
ODB1 fault codes print a copy and stick it in your cubby.
Insert pithy quote here.
engine
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
