Check Engine - Defender Source
Old August 27th, 2016, 11:48 AM
MMC415
Marc C
1997 D90 LE
Check Engine
I have been having ongoing electrical issues that were resolved after finding a bad connection at the starter motor signal wire and repairing. The battery on the truck battery died completely and had to be replaced. Now the truck runs but cannot get inspected due to a bunch of random error codes.
Also, just noticed that when I turn the key the check engine light does not come on prior to starting it. I guess could be a bulb issue but does anything else ring a bell of how to reset the system? I've tried driving it some distance but still doesn't reset.
engine
D-90 Door check or check rod question dfscott Defender Technical Discussions 6 November 29th, 2005 11:51 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
Check Engine Light after I was screwing around with fuses... P1CR Defender Technical Discussions 3 April 1st, 2004 04:56 PM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
