Check Engine - Defender Source
Old January 25th, 2009, 03:36 PM
bennett's Avatar
bennett
Bennett
'97 Defender 90 Soft Top #1140
Check Engine
I just had a water pump and belt tensioner replaced on tuesday, and had the coolant filled and the system pressure checked at that time. I drove to tahoe to spend the week here, and the check engine light came on. OBD2 codes were P0116 and P3999. Coolant looks fine and i haven't been running hot, so i assume its the thermostat or a sensor. I have reset the codes and they haven't come back. If you were me, would you get it checked out, or just keep an eye on the fluids until i head home next week? Also, i couldn't find P3999 anywhere, though some have stated on the forum that it may be a bad O2 sensor.
Bennett
engine
« ooops | Car Talk »
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
check engine light. FREEDOM Defender Technical Discussions 14 May 31st, 2005 01:10 PM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
