Check Eng Code 1138...any ideas ??? - Defender Source
Old August 9th, 2004, 03:20 PM
C-Delta
Robert Andre
SIIA 1967--GM350
Hello
Need help, have a 99 Discovery V-8 auto about 80,000 miles,
have a 1138 coming from the code reader.
All I can come-up with is; HO25 failed to switch to lean, bank "A"
have no idea were to start. Any help will be appreciated.
Rm Andre
Old August 9th, 2004, 03:50 PM
I might try looking here
http://www.disco2.com
They may have a better idea about the D2s then us
Check engine light mjekogian Defender Technical Discussions 7 February 21st, 2006 02:19 PM
Check engine light and code P1176 wingnut Defender Technical Discussions 5 October 7th, 2005 07:41 PM
Fault Code Help howellm70 Defender Technical Discussions 1 January 30th, 2005 05:43 PM
Check Engine light, code 17 mchombeau Defender Technical Discussions 3 March 17th, 2004 06:12 PM
