cheap but nice rear mat for D90 - Defender Source
Old August 14th, 2010, 08:58 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Hello All,
I was @ Lowe's today looking for some rubber matting to cover under the front seats (to block the hot air) and found this.
It won't really work for my application (too thick/hard to cut) but it could make a great mat for the back of a D90 (and possibly a 110 and wouldn't need to be cut) being the perfect width, 100% (recycled) rubber and only $22.
I found it @ lowes but here's a pic if you want to try to find it elsewhere.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old August 15th, 2010, 12:02 PM
Grover's Avatar
Grover
Thumbs up
I made floor mats and a rear load area mat with similar material from Tractor Supply. Works great and it's cheap. The material I used is 1/4 thick and the back is lined with little bumps that keep the mat off the surface it covering.
Old August 30th, 2010, 07:06 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
hahahaha I bought the exact mat at Lowes, and I use it all the time.
I also bought a nicer, but not much more expensive rear loadmat at lowes (they were having a sale on wool oriental rugs) and then had it cut to fit, and it came in approx. 150 under just what a rubber mat would cost for both.
Old August 30th, 2010, 07:54 PM
I too have the same mat which doubles as a mat for crawling underneath when I'm trying to fix something at the roadside!
90, d90
Nice cheap RRC in OC, I mean really cheap Neil McCauley Misc. Chit-Chat 2 June 5th, 2008 02:31 PM
ST Rear Mat Troys Wanted 0 April 12th, 2007 10:35 PM
Atlantic British Rear Cargo Mat $200 HUMMER80401 For Sale - Parts 3 May 20th, 2006 11:48 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
rear diff and rear seatbelts for '94 D90 rover_rich_d90 Wanted 1 April 20th, 2004 08:54 PM
