Chassis Rust Protection - Eastwood - Defender Source
Old October 23rd, 2015, 03:13 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
Hi,
I am looking to take care of the light surface rust I have on my 110 and also provide a barrier against / slow down new corrosion. I have been looking at products that Eastwood has. Does any one have any experience with Eastwood or suggestions of other products?
Thank you
Ben
Old October 23rd, 2015, 03:17 PM
this guy Ben Dutton started a good discussion on chassis coatings last year. you may want to reach out to him.
http://www.defendersource.com/forum/...ing-58073.html
search eastwood
Old October 23rd, 2015, 03:19 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
Thanks!
Old October 31st, 2015, 04:17 AM
apeerlessdude
Cris Scarborough
None at moment
http://m.summitracing.com/parts/poi-...FUiQHwodzoQEvg
Just put this on another post but this is a very good option to consider. I have been using it for a few years now with great success.
Old October 31st, 2015, 09:13 AM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
Lots of solutions for yo here
http://www.defendersource.com/forum/...tml#post684207
Old October 31st, 2015, 10:55 AM
JackW's Avatar
JackW
Jack Walter
1966 109 SW Diesel
POR15 - don't get it on your skin because you will have to wear it off
Old November 1st, 2015, 07:40 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Originally Posted by Ben Dutton View Post
Hi, I am looking to take care of the light surface rust I have on my 110 and also provide a barrier against / slow down new corrosion. I have been looking at products that Eastwood has. Does any one have any experience with Eastwood or suggestions of other products? Thank you Ben
Ben, this is a recent pic of my 18 yo chassis that has been driven on a daily basis here in Virginia for 12 years on trails, mud holes and salty NOVA roads.
I spray it down, inside and out, with WD40 a couple times a year.
Old November 1st, 2015, 09:49 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Which product did you use? Just WD40?
Old November 1st, 2015, 09:53 PM
1of40's Avatar
1of40
1of40
yep. I buy a gal for $20 and spray it with a plastic garden fertilizer sprayer.
Old November 1st, 2015, 09:56 PM
DailyDrivenDefende
Michael
I noticed WD40 loosens up a lot of grease gunk really well and dresses the chassis well. I suppose I need to get existing rust under control first then keep up with WD40.
Old November 1st, 2015, 10:05 PM
1of40's Avatar
1of40
1of40
yep I used it to clean an engine and trans before swap/install. Soak it with Wd40 and come back the next day with brake cleaner.
Old November 12th, 2015, 01:40 AM
cowboy
steven
'84 110 & '90 127 LHD 2-carb V8's
Hi,
Thank you
Ben
FWIW, Eastwood's "Exo-Armour" is written up in the January 2016 edition of Car Craft Magazine, which is out on the stands now. Sounds interesting - non-glossy & "invisible", so you're not covering anything up.
Old November 12th, 2015, 06:02 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Hi,
Thank you
Ben
I use several Eastwood products and love them.
Old April 27th, 2017, 04:57 PM
Surf90's Avatar
Surf90
C.S.
1989 Defender 110 200tdi
Hey guys. Is there a tutorial anywhere on the steps to take with rust prevention via WD40? Or is it literally just clean it really good and spray everything down?
Old April 27th, 2017, 05:19 PM
1of40's Avatar
1of40
1of40
I've found the beauty of it is its simplicity. You can't screw it up IMO. I'm sure if you got it on something you didn't want to you could hit it with brake clean. I teenage son and I were replacing brake pads on his D1 last weekend and his calipers look like hell. Mine have no rust or corrosion. He's jelly.
Old April 27th, 2017, 11:36 PM
Surf90's Avatar
Surf90
C.S.
Ha. Alright awesome! Putting it on my weekend to do list
Old April 28th, 2017, 12:43 AM
ghoregon
Greg H
1984 Defender 90 Ex-MoD
Think I'm going to start following this method. So do you just park on a tarp or something and spray the wd40 on pretty much anything that can rust on the undercarriage? Spray it and let it sit for awhile?
Greg
Old April 28th, 2017, 07:35 AM
1of40's Avatar
1of40
1of40
Originally Posted by ghoregon View Post
Think I'm going to start following this method. So do you just park on a tarp or something and spray the wd40 on pretty much anything that can rust on the undercarriage? Spray it and let it sit for awhile? Thanks, Greg
Yes, I use a garden sprayer and spray the inside and outside of the frame and crossmember, wipe down the hinges and roll bar and I use the can's straw to get into the weep holes of the doors.
I would recommend spraying lightly at the beginning to form a base. Let it dry and hit it again in a week or two. I feel now mine has a good base and really only requires touch ups. It not thick and messy but does a good job of fending off the sprays from the street year round.
Old April 28th, 2017, 12:45 PM
cowboy
steven
Garden sprayer as in a pump sprayer? And you're buying WD40 by the gallon from somewhere?
Old April 28th, 2017, 12:47 PM
1of40's Avatar
1of40
1of40
correct. Home Depot.
Chassis Protection / Rust Proofing Ben Dutton Defender Technical Discussions 63 December 9th, 2015 05:55 PM
Chassis rust removal and protection Hache Smaller Projects 31 April 20th, 2014 12:12 PM
Eastwood chassis black lordhelemt Defender Technical Discussions 7 December 21st, 2013 03:40 PM
Por 15 vs. Eastwood the_eaze Defender Technical Discussions 18 April 13th, 2010 07:38 AM
