Chasing water leaks - Defender Source
Old September 14th, 2014, 12:06 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Question Chasing water leaks
So it's time to put my new headliner in but the alpine windows leak when it rains. The seals were brand new when I did the rebuild a few years ago and I used the proper tool to install the locking strip. I installed the seal with the joint at the top, which is where it leaks. Will putting the joint on the bottom eliminate this? Any ideas are appreciated.
ID:	102856   Click image for larger version
Old September 14th, 2014, 07:42 AM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I also replaced the window rubber when I restored the top to my 94, but as you mentioned, I put the joint on the bottom of the window rather than the top. That way gravity is not working against you. I have had mine in for over a year with no leaks. Sorry, seems like a lot of rework.
Angus
Old September 14th, 2014, 08:08 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Both my trucks have seals at the bottom.
Old September 14th, 2014, 03:51 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Makes sense. I don't remember why I put the joint on the top or if I even thought about it. I guess I'll flip it to the bottom and see if that solves it.
water
Losing water from the expansion tank, no leaks/contamination, I think its the block.. Neil McCauley Defender Technical Discussions 9 June 22nd, 2012 02:56 PM
Chasing Classic Cars Visits Copley? specops1526 Misc. Chit-Chat 18 October 24th, 2009 10:38 PM
Copley Motorcars Corp on Chasing classic Campbell Misc. Chit-Chat 0 October 17th, 2009 12:32 PM
Water Leaks in the rain okyrover Defender Technical Discussions 5 March 31st, 2007 07:00 PM
When it leaks, it LEAKS Hans Misc. Chit-Chat 2 December 2nd, 2004 02:45 PM
» Defender Registry
cougar
couga861900
#894
MyD90
Add your Defender
