Chasing leaks, Engine Rebuild. - Defender Source
Old May 9th, 2016, 02:51 PM
RickM
Rick Mabus
95 D-90 ST
Hey all. I wanted to get some opinions. I have a 95 D-90 that I have owned since 2001. I have been gradually replacing a lot of stuff on this truck, but lately I cannot seam to get leaks to go away. I was chasing an oil leak on the front end of the truck, and it got fixed recently. Then the power steering hoses started to fail, fixed. This weekend, I was driving it around some and started to notice my small occasional drips of fluid were getting gradually bigger. From the top of the truck, the engine is really tight and clean. Under the truck on the driver side however it looks like oil is starting to come out of the side rear end of the block. It is dripping onto the lower round 2" cross member. Anyway, I have always fixed stuff, but I have never considered an engine rebuild, or a head gasket job. I feel as if overtime I find a fix, it causes another week link to become weaker. Wondering if an HG job would get me back on solid footing.
Old May 9th, 2016, 02:56 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Isn't ignorance bliss? Had you not fixed the first one you'd not be looking as attentive and as often. You're on a slippery slope now my friend.
Old May 9th, 2016, 03:01 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Also, at that location it could be engine (RMS) or trans oil (input shaft seal), or clutch slave cylinder (brake fluid). Make sure you know what is coming out.
Angus
Old May 9th, 2016, 03:47 PM
you own a truck made 21 years ago that probably has never had its seals replaced and so you are the stuckee. grin and bear it
as for headgaskets, what that has to do with an oil leak i have no idea. like the other guys have said , you really need to figure out where the oil leak is coming from. it could be a valve cover gasket...who knows
Old May 9th, 2016, 03:58 PM
Grover's Avatar
Grover
Every rover 3.9 - 4.6L I have seen leaked from the rear main seal area.
Old May 9th, 2016, 04:03 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Originally Posted by RickM View Post
H Under the truck on the driver side however it looks like oil is starting to come out of the side rear end of the block. It is dripping onto the lower round 2" cross member.
Like the other guy said, pressure wash/degrease-whatever and check closer.
Could be the crucifix seals---which is sorta close to a rear main seal but is not a rear main seal.
That is a known leakage area in older trucks.
Rent my
engine, rebuild
Chasing water leaks RiftRover Defender Technical Discussions 3 September 14th, 2014 03:51 PM
Oil Leaks and Pressure build up on 19J 2.5TD Engine richord Defender Technical Discussions 9 August 13th, 2014 06:16 PM
Chasing Classic Cars Visits Copley? specops1526 Misc. Chit-Chat 18 October 24th, 2009 10:38 PM
Copley Motorcars Corp on Chasing classic Campbell Misc. Chit-Chat 0 October 17th, 2009 12:32 PM
When it leaks, it LEAKS Hans Misc. Chit-Chat 2 December 2nd, 2004 02:45 PM
