Charcoal Canister - Capped Line Safety Question? - Defender Source
Old July 7th, 2008, 10:49 AM
R. Kurk
Richard Kurk
1993 110 NAS #489
I have disconnected and capped off the hose (canister side and plenum side) from the charcoal canister to the plenum as an experiment to see if a frustrating ‘rough running’ problem goes away on my 93 NAS 110. After the driving the truck last night and this morning it runs much smoother. Because the problem is intermittent (randomly smooth then rough/coarse running) I am going to replace the canister purge valve/solenoid which appears to be sticking/stuck in the open position.
I have ordered the solenoid but it will not arrive for about 2 weeks and I have a trip planned for the truck. Question … can I leave the hose from the canister plugged for a few weeks? Will fuel accumulate in the canister and either cause damage or worse create a fire/safety issue? Should I open up the hose occasionally to vent the fuel?
Rich K.
Old July 7th, 2008, 12:30 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
It should be fine, it will either build up pressure in the tank or vent to the atmosphere. You could run it straight to the plenum if you felt so inclined but that may bring you rough running problem back.
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
Oil Cooler Line Orientation Question dnewman9 Defender Technical Discussions 3 April 9th, 2011 06:24 PM
Charcoal canister ini88 Defender Technical Discussions 3 March 27th, 2008 05:46 PM
Charcoal Canister/Evaporative emission control Antonios Defender Technical Discussions 8 March 19th, 2006 10:35 AM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
