Changing vacuum advance actuator on NAS v8 - Defender Source
Old September 7th, 2014, 04:58 PM
Does the dizzy need to come out or can it be done in situ?
Old September 7th, 2014, 05:21 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
In situ. One screw has to come out the other is in a slot in the advance unit.
Worst might be having to loosen the dizzy securing nut and rotate to gain access to the screws. Obviously, make sure you mark the position of the dizzy clearly and/or time the engine when you are done!
Email is
Same place, new dogs.
Old September 7th, 2014, 05:26 PM
thanks !
Old September 7th, 2014, 10:14 PM
in situ, its a breeze dont drop any screws
Can a loose vacuum advance diaphram assembly cause stalling issues? Neil McCauley Defender Technical Discussions 5 June 14th, 2010 03:51 PM
Vacuum Advance revtor Wanted 2 June 2nd, 2008 11:24 AM
Vacuum Advance Andrew Vick Defender Technical Discussions 11 April 27th, 2007 08:25 AM
Vacuum Advance CGunther Defender Technical Discussions 0 September 28th, 2006 12:52 PM
Off-topic, Need DiscoII door lock actuator... RedRhinoProducts Wanted 0 January 19th, 2005 05:57 PM
