changing transmission oil - Defender Source
Old November 9th, 2006, 12:30 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
I looked but couldn't find a post on it. Basically i need to change my transmission oil. I have 3 quarts of Redline MTL, the right size Torx wrench and pump and i think im ready to go at it. BUT i don't have a manual or anything to go off.
Does anyone have some photos of where the drain is and where i pump it into?
I was told to just tilt the truck up and you will find it all underneath.
is it this simple? i sure hope so!
Old November 9th, 2006, 12:53 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
Yup, drain plug on bottom of transmission case, fill plug on side. Take both out after a run. Get new copper washers, or replace plugs with magnetics. Once drained, replace drain plug, fill via side plug with preferably a pump type container till the fluid starts oozing out of the fill hole. Replace fill plug, torque to spec. Drive around a couple of days, re-check tightness. Enjoy smoother shift..
Old November 9th, 2006, 01:09 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Last time I did this I didn't have a clean pump -- wound up removing the passenger side floor and used a plastic hose to pour the fluid in -- worked great.
Old November 9th, 2006, 01:11 PM
ini88's Avatar
ini88
Daniel Marcello
Thanks! will the Land Rover Genuine Parts Magnetic Drain Plug (FTC5208) #18677 fit as the magnetic plug for the drain?
EE has thisone fo the Diffs, but is there a specific one i should get for the tranny?
Old November 9th, 2006, 01:20 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
I got the EE plugs, they fit on the diffs, trans, and transfer.
Old November 9th, 2006, 01:43 PM
the plug on my gearbox was magnetic already.
Old November 9th, 2006, 02:21 PM
thewap's Avatar
thewap
Marc
'95 D90 SW#106
If I remember correctly, mine too.
Old November 9th, 2006, 04:00 PM
artm
Arthur Maravelis
97 SW
Never remove the drain plug before undoing the fill plug on anything. What if you can't open the fill?
Old November 9th, 2006, 04:17 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Good Point Art.
Old March 26th, 2009, 02:23 PM
bjf's Avatar
bjf
barry f
94 ST #395
What does the pump needed to do this look like?
Old March 26th, 2009, 02:26 PM
ini88's Avatar
ini88
Daniel Marcello
you can find them at most auto stores. the nice one screw onto the top of the bottle and just pumps the goods out and up into the tranny.
http://images.outdoorinteractive.net/mgen/528396_oi.jpg
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 26th, 2009, 02:31 PM
bjf's Avatar
bjf
barry f
94 ST #395
learn something new daily.
thanks
Old March 26th, 2009, 04:15 PM
ini88's Avatar
ini88
Daniel Marcello
they are cheap too! use it for the tranny, diffs and t-case and get is nice and oily and throw it out after if you want.
1955 Series I
1975 FC101 Vampire
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old March 26th, 2009, 04:22 PM
artm
Arthur Maravelis
97 SW
The last one I bought was free - came with a gallon jug of 80/90!
Of course, you can refill the jug when it empties so you can still use the pump.
Old March 26th, 2009, 08:29 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
Whats up with the pump just us a funnel.
Old March 26th, 2009, 08:46 PM
artm
Arthur Maravelis
97 SW
Funnel's only good for the ZF...try using it on a diff or anything else...
transmission
V8 Engine Oil - Synthetic vs Semi Synthetic nickt Defender Technical Discussions 68 September 18th, 2016 09:38 AM
Defender Oil Cooler Status Poll: Please Read. Hans Misc. Chit-Chat 4 March 12th, 2006 10:49 PM
Oil leak rustydefender Defender Technical Discussions 19 December 9th, 2004 09:06 PM
