Changing timing belt 200 tdi - Defender Source
Join the Defender Source Community Today
Old September 14th, 2016, 01:29 PM
johnnydakota
1991 Defender 200 tdi
Hi all,
I have my Defender stateside now (I will post photos soon) thanks for all of your help so far. I want to change the timing belt because I don't know the service history on it. Is there anything out of the ordinary which could potentially stump a mechanic or is this a pretty straight forward job? The engine is a 200 tdi. Thanks!
Old September 14th, 2016, 01:45 PM
AdamSanta85's Avatar
AdamSanta85
1991 D90 SW
I just went through this exact case myself. I did the timing belt myself, with assistance of my mechanic friend.
Some things to note....
1. It is a good time to do water pump, thermostat, coolant hoses if needed. Everything but thermostat has to come off anyway.
2. Make sure you get good quality parts and seals. Dayco belt, OE belt tensioner, Corteco seals etc
3. A viscous fan spanner will help getting the fan off. I got one for $18 off eBay. LINK
4. They sell a injection pump timing pin kit, and flywheel timing lock kit on eBay for about $10. This will make sure everything is timed correctly. Buy it. LINK
5. Removing the crank bolt, and pulley can be a real hassle. Mine wasn't bad, but I heard it can be. There is a specialty puller for sale for this on eBay if you feel the need to buy it. This kit includes the timing pins mentioned above so you wouldn't need both. LINK
6. Now would be a good time to replace inner crank seal, and camshaft seal. While the cover is off you will have pretty easy access to them.
7. Make sure he follows the manual on setting timing belt tension. You have to set it, turn engine over, and then re-set it again. Not a big deal, but follow the book.
I have done a few other timing belts before. This was about as difficult as a Honda civic. Maybe easier because once you get the fan/shroud out of the way, you have a lot of room.
Make sure you get the genuine workshop manual (you can download it) and read it carefully. Make sure you use OEM parts.
Here is a writeup: Defender 200TDI timing belt change - Land Rover Technical Archive - LR4x4 - The Land Rover Forum
If you have a Discovery engine, the procedures are different and you will want the Discovery manual.
Old September 14th, 2016, 02:17 PM
Naplm00
Matthew
Added to the above comments. I use rtv on both sides of the water pump gaskets and the timing cover area. Also a thread sealant is a good idea for the bolts in this area as they are subject to water.
Old September 14th, 2016, 03:14 PM
Use antiseize when putting the water pump and cover bolts back in.
Worldwide Land Rover Shipment and Importation Service
Bespoke Restoration & Modification work
Old September 14th, 2016, 04:16 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You'll need the special tools as seen in the video below.
You'll want to replace the water pump as well and the head gasket and rework the head if needed.
Why?
Since the front cover and lid contains coolant flow and when a head gasket blows it pressurizes the cover and ruins the gasket... fixing this requires you to tear the whole front off the engine to renew the front cover gasket (to fix the coolant leak).
I pull the head, have it checked for cracks & flatness, check the valves, replace the valve seals.
If head work is need, we do it then often installing new valves and guides and having it skimmed.
Then we install the head with new gasket and new head bolts, injectors, and glow plugs are checked and replaced as needed.
Then install the front cover, timing belt and water pump.
Sounds like overkill, but it's better than doing a timing belt, then having the head gasket blow, and then doing the head, and then doing the timing belt a second time.
RDavisinVA
Old September 16th, 2016, 02:10 PM
johnnydakota
Thanks guys! I will print out those instructions to give to the mechanic & I will have those seals done as well while the cover is off. Thanks for the suggestion of the tools Adam, I wish I had read your post more carefully the first time because I wound up buying the kit from Rovers North & it was $120!
tdi
Used Proline 200 TDI Radiator & 200 tdi intercooler mgreenspan For Sale - Parts 4 April 8th, 2014 03:38 PM
Changing timing chain, TDC, and the crank pulley assembly question flananuts Defender Technical Discussions 4 May 14th, 2012 10:16 PM
Head Gasket, Timing Belt, Drive Belt - What else? GreenRover Defender Technical Discussions 5 July 16th, 2010 12:23 PM
300 Tdi Timing Belt roverboy For Sale - Parts 3 March 27th, 2007 09:06 AM
