Changing Steering from RHD to LHD - Defender Source
Old August 26th, 2013, 07:11 PM
riffs1
Sheriff Ngobeh
1994/Defender 90
Am I correct that to change from RHD TO LHD, I would need the following:
Steering Box
Dashboard
And if so, does any one know where I can source these parts
Many thanks
Old August 26th, 2013, 07:23 PM
Landy_Andy's Avatar
Landy_Andy
Andy
Here is the parts list I found last year.... can't remember what site it was off...
Dash Sub Frame MXC8575
Dash trim MWC9339PMA
Dash Handle MTC6142
Heater fan Decal MTC6007
Heater Label Def. MTC6006
Drag link end NRC8232
Panhard Rod ?
Wiper rack tube PRC3762
Brake Pipe NRC7902
Brake Pipe NRC7904
Power Steering Hose ?
Instrument Bezel MTC5459
Steering Box MTC1583
Steering Bracket ?
Lower dash MTC2827
Wiper Cover MTC6080
Parcel tray MRC7283 / RNI595
Finisher MTC6167
Grey Trim Panel MTC4618
Heater Control Assy UTP1125 / RNF412
Heater Defrost Control 347586
LHD wiper arms DKB000050PMD
Power Steering Hose (Pump to Box) RNH405
Dash Trim Panel RNI657
Hope that helps.... BTW, RaRo classic's are good donors for the steering parts
Old August 26th, 2013, 08:15 PM
Yep, swivel assembly for the drag link to connect to and the actual heater itself. Pretty sure the steering bracket listed is the panhard rod mount as they are sided,the panhard rod itself is not.
Old August 27th, 2013, 06:59 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Doug's site has a good write up on a conversion. The LHD dash parts are getting very hard and expensive to find. You can re-use the dash you have but need to make some modifications to it to make it work. You do have to have the steering gear box, and heater box as they are LHD specific. You can find some used swivel ball housings off a Discovery but get everything as your truck may have a different style.
Old August 27th, 2013, 07:32 AM
rovertrader's Avatar
rovertrader
Dale
D-I front axle with D-90 front brakes is your best bet, as there are a few different Defender front axle assemblies, and the hubs vary, making steering components difficult to fit.
rhd, lhd
LHD manual steering box aosias For Sale - Parts 8 February 14th, 2013 06:41 AM
FC101 LHD steering assembly Hoosier For Sale - Parts 7 October 16th, 2012 08:18 AM
200TDI LHD power steering hoses RiftRover Defender Technical Discussions 10 June 15th, 2009 06:40 AM
