Changing Starter - Defender Source
Old January 21st, 2008, 06:06 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Changing Starter
Anyone have any tricks to getting to the upper allen bolt? I can't get the hex key in since I can't see the damn thing.
Old January 21st, 2008, 06:18 PM
JSQ's Avatar
JSQ
Jack Quinlan
Make sure you're using a 8mm 3/8" hex socket with a breaker bar rather than some kind of key.
Your life will be much easier.
Preparatory application of PB Blastr will also help.
Old January 21st, 2008, 06:22 PM
Andrew Vick
Andrew Vick
95 D90
Don't remember the sizes, but mine was a different size than the bottom ones.
Old January 21st, 2008, 06:42 PM
You should be able to get to that one from above. That or with a long extension and universal joint on the end, come in from the front side of the engine.
hth
charles
Old January 21st, 2008, 07:30 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Oh No.
Are the rest of you finding this to be true?
I am using the 8 mm hex for both but I can't see the upper bolt to even no if it is correct.
Old January 21st, 2008, 07:51 PM
Andrew Vick
Andrew Vick
95 D90
The upper was smaller, and it took forever to figure out. I thought "there's no way the upper bolt would be different", and sure enough, it was. Try going down a size.
Old January 21st, 2008, 08:30 PM
Ditto on the hex socket, but on both my trucks, the top was the same size as the bottom.
charles
Old January 21st, 2008, 09:54 PM
JSQ's Avatar
JSQ
Jack Quinlan
They are both 8mm.
Old January 22nd, 2008, 12:31 AM
bjenk
Brian Jenkinson
1994 D90
Be prepared!!! this was the hardest repair of my 90 yet...I just kept telling myself "Two Freak'n Bolts, nothing more, nothing less...
I stripped the hex (oh I blasted it for a couple days with bp), used a dremmel and slotted the head and it stripped, Cut the bolt head off....ha the starter was out...Bp blasted more. Started to get the studs outs, one came out the other broke right at the housing. I drilled out the bolt and the bolt extractor broke off inside the bolt...I ended up getting a very expensive drill bit (robinson bit) and was finally able to drill through and put a nut on the other end...
I was besides myself the entire time and would lay under there looking at those bolts for hours.
Good Luck with it.
Old January 22nd, 2008, 12:16 PM
Emerson00
Matt J.
None at the moment
Great.
Replacing my starter happens to be my project for Saturday morning. The starter was just delivered yesterday afternoon.
I will attempt to keep my whining to a minimum.
Old January 22nd, 2008, 05:59 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Good Luck with it.
I feel the pain.... Now I am glad I was luckier..... The top bolt is accessed from the top. Mine was PB'd for two days every two or three hours to no avail. Tried to heat (hot enough?), could not attach a wrench, ended up cutting the head with a small 4" grinder (perfect size). Took roughly 4-5 hours (between going to the local Home Depot to get that "advance gas" cartbridge and other pliers / wrenches / etc. to try to get it out. Now, I'd just cut the bolts.
Both bolts were the same size on my '95 D90.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old January 22nd, 2008, 09:57 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
So were both bolts difficult for you guys? I got the bottom one out but couldn't even engage the top one to try. I put everything back together and I am driving it again as is.
Old January 25th, 2008, 10:25 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Both the same. The top one is done with a long extension so your ratchet handle is near the front diff.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 25th, 2008, 10:33 AM
Emerson00
Matt J.
None at the moment
Tom,
Is that the same setup as on your '95 D1? That should be similar to the RRC of the same year, yes?
Old January 25th, 2008, 08:53 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Not sure about the RRC. That's an illustration from the Discovery manual, but I used the same tools on my Defender.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 28th, 2008, 09:30 PM
So how did it go?
Old January 29th, 2008, 10:18 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
If you are talking to me, I haven't attacked it again. Its been snowing so much that all I do is shovel my driveway and ski. Mostly the latter and my driveway shows.
My 90 still starts but every 3rd start or so it just whines instead of turning over. I stop cranking it and start again and it usually turns over. Its like something is sticking in the starter.
Old January 29th, 2008, 10:29 AM
Emerson00
Matt J.
None at the moment
Mike, I did manage to get mine out. Having read this thread, I was really careful about that top bolt. The diagram Tom posted did work for me as well, though not as much for the upper bolt.
I took my time blindly finding the top bolt with the hex/allen socket with an extension. Tapped it firmly into place and then pt the ratchet on it with a 2.5 foot pipe on the ratchet. It broke free first try though only at the extreme end of the ratchet's available arc. I thought I was screwed when I heard the CRACK! Even then, I first thought I spun the socket in the bolt head...
I spent 10x the time planning the position and make-up of the wrench I would use as I did backing the bolt out. I loaded it up real well with PBlaster shot through the exhaust manifold beforehand; perhaps that helped, too.
It was also an 8mm
Old January 29th, 2008, 11:07 AM
Devin W's Avatar
Devin W
Devin Walton
Both of my bolts were the same size, too. Although I could reach the top bolt from the top, at one point, I felt that it was starting to round out, so I just pulled the manifold to avoid the hassle of a stripped bolt head. Fortunately all of the manifold bolts were far easier to work with than the stupid starter bolt and it took the frustration factor down significantly since I could more easily access the bolt securely.
start, starter
Starter issues on my D90 Rover- Girl Defender Technical Discussions 13 February 13th, 2010 10:59 PM
Compatible starter motor question? MiniGuy Defender Technical Discussions 14 January 3rd, 2006 10:58 PM
Starter solution for TD D90? torque Defender Technical Discussions 0 April 30th, 2005 11:10 PM
Starter going bad? loykd Defender Technical Discussions 6 September 15th, 2004 10:12 PM
Fun new problem: starter circuit issue jaherring Defender Technical Discussions 1 September 12th, 2004 03:07 AM
