Changing oxygen sensors - Defender Source
Old July 29th, 2012, 12:10 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I searched but could not find a good answer to this question. I ordered new oxygen sensors and the socket tool from AB. I figured out how to unplug the sensors and I have squirted the sensors with PB blaster.
What is the best way to take the sensors off?
It looks like the right one is accessed from the top and the left one from below??? It looks easy enough, but for some reason I am expecting a fight with these.
Oh yeah, 95 3.9L GEMS engine. For what is worth the O2 sensors have been in there for 272,000 miles......
Old July 29th, 2012, 01:07 PM
Grover's Avatar
Grover
Craig,
First off, congratulations on such high mileage. You must take good care of the motor.
The o2 sensors are just threaded into the y-pipe. Over the years the threads have rusted. Soak them with pb- blaster like you have been. I have smacked the nut of the sensor while it was hot to loosen.
Good luck...
Cheers...
Old July 29th, 2012, 08:25 PM
Break them loose with your little O2 sensor tool snip the wires off the old sensor it will make them easier to unthread. I use a little anti seize on the new ones. Good luck, congratulations on the high mileage.
Old July 29th, 2012, 09:07 PM
Craig....original motor, no rebuild? Is tht right? Please - what's your secret!
Old July 30th, 2012, 11:54 AM
Craigd's Avatar
Craigd
Craig Dickson
Original motor, no rebuild, just head gaskets once. Change the oil every 3,000 miles use Mobil 1 synthetic primarily highway miles. I also drive like an old lady.
I think these vehicles like to be driven. The 90 was my primary driver for most of its life and now that my wife does not drive I get to pick between two other vehicles to drive every day. My 90 now gets driven about once a week and it rewards me by needing new O2 sensors.
Old July 30th, 2012, 12:07 PM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
With that kind of mileage, I'd be shocked if they came out easily. In addition to penetrating oil, consider being ready with a torch too (something other than propane), MAP or oxy. You'll probably have to heat the y-pipes until they are really toasty before those things break loose. I'm not sure what AB offers by the way of a socket, but you may opt to cut the wires on the senor and use a full socket to twist them out, then use your sensor wrench (or just an open wrench) to put them back in.
You may want a six-pack nearby too. Just a thought.
Old August 7th, 2012, 11:56 PM
Craigd's Avatar
Craigd
Craig Dickson
I just wanted to update the results. Found that when using the O2 socket tool from AB you have to set the socket wrench to tighten, as the offset nature of the tool causes the tool to twist backwards.
Anyway, I was very lucky.
Took about 20 minutes of fiddling around to figure out which way I was turning and the right side came off. Left side took maybe 3 minutes. I am sure having a Colorado rust free truck helped things. It went so smooth I forgot the beer. Reset the light and so far so good.
I have not checked the plugs yet but do you think the right bank is fouled?? I suppose it goes without saying that if I change any plugs I should do them all.
Old August 8th, 2012, 08:04 AM
Any fouling will clear if it's running right
Old November 1st, 2012, 03:31 PM
Craigd's Avatar
Craigd
Craig Dickson
Wanted to give an update because many times we never hear what the final result is. Anyway light came on a few days later so I took the truck to a reputable Rover shop. They checked my o2 sensor installation and determined that they were installed right and working. Cleaned Coil contacts and PVC stuff and reset base idle. Truck ran like a champ for about 100 miles and light came back on and started running rough again.
Took it back in and they checked the usual's and thought it may be clogged fuel injectors. I do have 273,000 miles on the engine.
The shop gave me a can of BG44K to dump in the fuel tank when i refueled. Ran a tank of gas through and so far so good. I reset the light and after driving on and off for the past two weeks everything appears to be working. The truck is also running well with no more idle issues.
In hindsight the o2 sensors were probably okay but at least now I know they are new.
Old November 1st, 2012, 03:35 PM
Grover's Avatar
Grover
Good to hear you got it running.
273k...very impressive
Old November 1st, 2012, 03:37 PM
I always like to change the oil after using those fuel system treatments, esp the BG.
Old November 1st, 2012, 04:52 PM
Craigd's Avatar
Craigd
Craig Dickson
The oil change is good advice. Will do.
Old November 2nd, 2012, 04:38 PM
red&yellowrovers's Avatar
red&yellowrovers
Joe Still
95 D90 NAS 3.9l ST AA Yellow #2719
GEMS in a 95? I thoguht that was 97. js
sensor
Need to replace the Oxygen Sensors Cory Defender Technical Discussions 15 September 14th, 2011 11:15 AM
Oxygen sensors thewap Defender Technical Discussions 8 June 23rd, 2006 10:28 AM
anyone used the nissan oxygen sensors? mattdh Defender Technical Discussions 23 April 19th, 2006 07:54 PM
Oxygen Sensor Testing Antonios Defender Technical Discussions 6 April 1st, 2006 10:24 PM
OXYGEN SENSOR Question? ... Vendor ? norros Defender Technical Discussions 4 June 7th, 2004 07:14 PM
