Changing oil in the R380, do I need to replace a ring like the engine drain plug? - Defender Source
Old September 6th, 2013, 11:24 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
Just curious if I need to get a cooper ring for the 380 drain plug similar to when I changed the engine oil?
Old September 6th, 2013, 03:12 PM
Maybe a good idea, but mine have never leaked and I have not replaced them.
Old September 6th, 2013, 08:00 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Take the old ring/washer and sand it by hand with a little oil on a piece of 300 or 400 grit sandpaper and it will be better than a new one.
- Charles Eames
Old September 6th, 2013, 09:04 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Permatex...
There is a low spot sort of like an o-ring groove that will hold a permatex gasket maker seal as well as the copper washer.
The sanding is good advice as well.
We fill with an Amsoil MTF94 synthetic equivalent...
RDavisinVA
Old September 7th, 2013, 08:29 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Robert, do you use that blend in other trans applications as well. I'm wondering about lt77 and lt95's.
Old September 7th, 2013, 08:43 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yes and Yes
I use the synthetic Amsoil MTF94 equivalent in the LT77 and LT95 as well.
For the LT77 Ashcroft recommends ATF Dextron 2 or 3 and every LT95 I have taken apart had oil in it. Usually 90 wt, but have seen lighter oils like 20/50 which Leyland motors recommended for the MGB.
My experience has been that the LT95 develops noisy bearings when filled with 90wt, but this is less common with the synthetic Amsoil MTF94 equivalent.
One thing is for sure the the synthetic Amsoil MTF94 equivalent will leak where no 90wt leaked before, so it is a good idea to replace any questionable seals.
RDavisinVA
ac, drain, drain plug, engine, r380
Engine Swap: which one? 200tdi, 300tdi, or something I dont even know about gonzanc Defender Technical Discussions 46 April 2nd, 2013 09:36 PM
R380 fill plug Glenn_Guinto Defender Technical Discussions 15 March 18th, 2013 04:19 PM
oil change/oil cooler line change sirjond Defender Technical Discussions 12 January 25th, 2013 03:01 PM
Oil pressure drops when engine warms up flananuts Defender Technical Discussions 19 September 7th, 2011 12:12 PM
engine oil chart from owners manual Eric_S Defender Technical Discussions 3 November 21st, 2003 10:40 AM
