Changing my r-380 fluid - Defender Source
Old August 25th, 2008, 12:08 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Is it easier to take the tunnel off to change the fluid or get some kind of pump to pump it up into the hole which is in a suck ass spot as usual.
Just changing all my Lube before MAR.
When I drained my t-case which had royal purple in it, it still looked new and there was basically no shavings on the magnetic plug... bravo...
Legend in My Own Mind.
Old August 25th, 2008, 12:34 PM
Grover's Avatar
Grover
Thumbs up
I used a hand pump purchased from Autozone to fill the diffs/t-case/transmission. It's well worth it...
Old August 25th, 2008, 12:52 PM
I have one of the "big syringe" type you get at Autozone, but I prefer the little ones that Napa and others sell that screw onto the top of the lube bottle. Its still a hand pump, but I think its a lot easier to control.
Old August 25th, 2008, 12:57 PM
Hand pump. While I am there I normally swap the internal torx bit for an external 1/2 head fill plug.
Old August 25th, 2008, 04:47 PM
discotdi
Todd Miller
Land Rover
Ron is that 1/2 in fill plug the same as the ones on the diff. etc.? the torx is a real pain.
Old August 25th, 2008, 05:01 PM
I like my t55 bit.
Old August 25th, 2008, 05:05 PM
discotdi
Todd Miller
Land Rover
t55 bit? don't know what that is. Is that the snap on or mac part or something? generally putting air in my tires is about all the mech. ability I have.
Old August 25th, 2008, 05:27 PM
discotdi
Todd Miller
Land Rover
Cool thanks. I am always amazed by what people on this site have pictures of!
Old August 25th, 2008, 11:28 PM
discotdi
Todd Miller
Land Rover
oh I thought you loved the t55 so much you snapped a picture last time you used it.
thanks for the info. will pick one up tomorrow.
Old August 26th, 2008, 10:30 AM
"Ron is that 1/2 in fill plug the same as the ones on the diff. etc.?"
You could use one of those (an INTERNAL half-inch square) but I prefer the external 1/2in square. I want to say they are drain plugs for the bellhousing of the transmission.
Old August 28th, 2008, 03:20 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I bought a hand pump at auto zone. It was one used for a board outdrive or outboard lower unit. I worked perfectly to pump in the new Royal Purple Fluid...
Old August 28th, 2008, 06:18 PM
Shoulda used the Redline....
Old August 29th, 2008, 08:40 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
No one sells that around here. The purple is all over the place. I like it. I'm sure the red line is no better or worse. I like synthetic stuff. I even use there grease for bearings and so on.
Old August 29th, 2008, 10:33 AM
See the other thread.
Old August 29th, 2008, 10:37 AM
Nobody sells royal purple around here in charlotte either. which redline should I be using for an R380
Old August 29th, 2008, 10:49 AM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I would like to hear how you like the RP over Redline. Everyone used to swear by Redline, but it seems the tables have turned and RP is all the rage now...
Old August 29th, 2008, 11:20 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I like the RP. No problems and they make a good manual trans fluid. I think its called syncromax.
Old August 29th, 2008, 11:27 AM
RP does not make an MTF spec fluid. It is either full gear oil or ATF spec.
YMMV
Ron
Old August 29th, 2008, 04:52 PM
I had the purple, went back to the red.
Old August 30th, 2008, 04:39 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
YMMV
Ron
Yeah they do.. its called syncromax.
While changing spark plugs mdmccallum Defender Technical Discussions 9 November 2nd, 2005 09:12 AM
Gear fluid ..... Rover- Girl Defender Technical Discussions 3 October 9th, 2005 05:25 PM
Power Steering Fluid Reservior fleabus Defender Technical Discussions 3 July 22nd, 2005 10:39 AM
ZF fluid level goes up and down 48vphantom Defender Technical Discussions 4 March 20th, 2005 01:42 PM
