Changing fuel filter question - Defender Source
Old July 3rd, 2008, 12:56 PM
ollieskins's Avatar
ollieskins
Wade Garrett
1994 defender 90
Hi all,
My truck is sputtering so I would like to replace the fuel filter. I already gave it a tune up, but still sputtering (even worse really). Anyway, my question is do I have to relieve the pressure in the filter before disconnecting?
Old July 3rd, 2008, 01:00 PM
Its nothing that cracking the fittings won't accomplish. Put down a spill pan, but whenever I've done it, it just dribbles out. There is little or no residual pressure in the system. I think the pump is only like 6 psi or something anyway. I forget exactly.
Old July 3rd, 2008, 01:14 PM
themaxx's Avatar
themaxx
Ade
94 ST
How often should the fuel filter be replaced? I think I read or was told every 30k miles.
Old July 3rd, 2008, 01:35 PM
I do mine a couple times a year, I usually pull the fuel pump relay when the truck is running maybe it helps get a little fuel out of the system.
Old July 3rd, 2008, 02:52 PM
Grover's Avatar
Grover
A couple times a year? Why so often?
Old July 3rd, 2008, 03:11 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
ocb
Robert Deniro
Old July 3rd, 2008, 05:57 PM
hamiamham
mike
97 D-90
my fuel filter lasted for 45k miles.
Old July 4th, 2008, 08:27 AM
its cheap compared to fuel pump and injectors and takes me about 10 minutes to do it.
Old July 5th, 2008, 11:27 AM
slickrock
Andrew Gold
94 D90
David,
If your Defender is running worse after you tuned it, check over what you tuned up. I'm guessing you rotor, your cap, wires... Before you change new parts, go back and check what you have already changed/ adjusted. Good luck
fuel
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Fuel Filter milli Defender Technical Discussions 3 January 21st, 2005 10:46 AM
Looking for a 300TDI Fuel filter EdHsu Defender Technical Discussions 2 September 12th, 2004 01:11 PM
