Changing Engine Mount - Defender Source
Old March 21st, 2008, 10:33 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Whats a good way to change engine mount in a driveway. I need to replace mine this afternoon. I was told by a few people that a bottle jack on the part of the diff will lift the engine for the right side perfectly to swap out the mount but what about the left side?
Chris von C
[/size]
Old March 21st, 2008, 10:50 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I did them when I still had the gas engine in the series with a 12"x12" piece of plywood on top of my floor jack and lifted from the oil pan.
Old March 21st, 2008, 11:54 AM
I agree with Kevin. I lifted one from the crank pully area as well.
Old March 21st, 2008, 01:14 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Cool, thanks. I assume that will lift both sides equally? Is there anything else I need to know aside from unbolting the 2 mounts first?
Chris von C
[/size]
Old March 21st, 2008, 01:31 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Make sure you don't jam you fan into the shroud and watch all other clearances as well.
Old March 21st, 2008, 02:54 PM
Don't put your fingers where they could get cut off if it falls. An engine hoist makes this much more pleasant and safer. Or a winch line and a tree.
Old March 21st, 2008, 03:31 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Loosen the transmission mounts as well--not sure it made changing mine any easier, but I certainly don't think it hurt.
Old March 21st, 2008, 05:45 PM
chrisvonc's Avatar
chrisvonc
Chris von C
I swear, I'm the worst mechanic on the planet. I couldnt have more things go wrong or couldn't find tools all friggen day.
So before I head under the truck again, am I correct in assuming the mounts screw into a welded nut on the other side of the brace on the engine, because I can for the life of me figure out how to get a wrench up there if they are free nuts up there.
Chris von C
[/size]
Old March 21st, 2008, 06:51 PM
They are free nuts, not welded. I think I used a gear wrench.
Old March 21st, 2008, 07:58 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Yeah I tried, not enough room from any angle to get mine in there. Looks like I will have to go buy a cheapo one and cut it in half. My full length ones wont get in there.
Chris von C
[/size]
Old March 21st, 2008, 08:06 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Didn't you learn anything from "The Gods Must be Crazy?"
Old March 21st, 2008, 09:51 PM
chrisvonc's Avatar
chrisvonc
Chris von C
Too late.. lets just say Santa will be thrilled with his new ride that currently stuck in my tree f he can get it out.
j/k..
I failed today. I need a half length wrench to get to the drivers side upper nut.
Chris von C
[/size]
Old March 22nd, 2008, 12:44 PM
Humm, how was I able to do this. Maybe a swivel joint and a socket?
Old November 19th, 2012, 03:31 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Reviving this thread for an additional question. So how high can I jack the engine before I start stressing the tranny connection? Looks like I moved the engine up about 1-2" and don't feel I am anywhere close to being able to slide the mounts out.
B
Old November 19th, 2012, 03:38 PM
B
Depends on how shot the other mounts are. The trans mounts will fail before the connection to the transmission will fail.
Old November 19th, 2012, 03:51 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Good. I didn't want to tweak it just as I am getting this thing back into running mode. Are you guys removing the brace that bolts to the engine that the mount then bolts to? Or are you just take the top and bottom nut off the mount and pulling it out?
B
Old November 19th, 2012, 04:20 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
that is what I have done
Old November 19th, 2012, 04:28 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Gracias. Didn't want to be doing something that turns out to be impossible to do. I have been down that path before.
engine, mount
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Is it ok to mount a 200tdi to an engine stand? dave_lucas Defender Technical Discussions 15 July 6th, 2009 12:34 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
