Changing a functioning fuel pump - Defender Source
Old February 13th, 2012, 05:24 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Thanks to some chuckle-head drunk driver, I'm going to be a recent recipient of a new rear-crossmember, gratis. Trucks got 78k on the odo, I haven't looked through all the past maint records yet, but don't think its had a new fuel pump.
Should I change it out even though its working fine while the tank is down to avoid the headache later? I can probably convince the LR body shop guys to let me take the tank for a one day conjugal visit.
Old February 13th, 2012, 09:10 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
Change the pump? Probably not. Could go either way. Cut out an access panel in the floor while the tank is dropped. Definitely.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old February 13th, 2012, 09:29 PM
J. Andrew's Avatar
J. Andrew
J. Andrew
95 D90 NAS SW #384
Yea i've seen the access panels, and although I acknowledge that it is a great solution, my rig has been heretofor unmolested, and I would like to keep it that way. I know its one of those instances where it can go tomorrow or in 200k miles, I just saw an opportunity to avoid doing yet again another project by myself with no one to help me, under a truck that I can't raise up more than 4 inches w/o taking it out of my garage.
Old February 14th, 2012, 10:10 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Yes, change the pump. Average life of an electric fuel pump is 100K miles. It's too easy not to do it now while you have easy access...and it's 17 years old.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old February 15th, 2012, 06:52 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
Agreed in the change. If your tank is dropped, replace the pump. It much easier than turning the key and not hearing the pump prime. At a minimum, I would clean up all the metal connection to the pump as mine were pretty gnarly in my 94 with 87k mikes and a lot of WVA clay
Old February 15th, 2012, 07:33 AM
LRover's Avatar
LRover
J. Michael McCaig
Yes on the pump as well and I would also check the rear suspension ball joint to see if it needs to be replaced while the tank is out of the way.
Old February 15th, 2012, 12:16 PM
Yup, change it and keep the old one as a spare.
Old February 15th, 2012, 12:22 PM
bjf's Avatar
bjf
barry f
94 ST #395
Here's my question. Why bother keeping it as a spare. If the new one fails would you really want to go to the trouble of dripping the tank to put an old one in?
Old February 15th, 2012, 12:30 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
Change. As for the spare, I have done this so many times(don't ask me why, it's too painful to relive), that I can have it out and back in in about an hour. I could trail fix if I had to. I also chose to go with fuel immersible lines from the pump to the external connections to make swapping easier. At his point though, I wish I had put in an external pump
Bill
Old February 15th, 2012, 04:16 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Good logic. But keeping it as a trail or trip spare is a good idea.
legend in my own mind
fuel
