Changed Thermostat now coolant leak - Defender Source
Old January 3rd, 2010, 04:34 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
The truck was overcooling so I changed the thermostat and after determining the fan was working right. After changing the thermostat and gasket, I filled it up the radiator and started the truck. No leaks after up to temp or under a load so I drove it around and check again, no leaks.
Parked the truck in the garage and took a peak an hour or so later and saw coolant on the ground, a couple of cups worth.
Trying to figure out where it came from? I dont see any coolant in the valley and the expansion tank has fluid in it.
Ideas?
Could it bet that I overfilled it and it leaked out the expansion tank?
Valley is dry both in the front and in the back (what I can see).
Old January 3rd, 2010, 08:06 PM
I think you are right Nick. I'd just keep an eye on it over the next few heat-cool cycles and I expect the leaking will have stopped.
Old January 3rd, 2010, 09:44 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
I've seen a few Rovers that begin to seep from the upper radiator hose at the t-stat housing when the weather gets really cold, but that usually will leave a puddle at the rear of the intake manifold. Oh, and I see you're in Texas. Well, it's a little cold here right now!
Email is
Same place, new dogs.
Old January 3rd, 2010, 11:09 PM
97-D90-736
Nick Vogel
It was coolant in the valley. Gave the motor and wash and no more puddles.
Now the water pump is seeping.
If its not one thing, its another!
coolant, thermostat
COOLANT LEAK, PLEASE Read this and help if you can...Thank you!! norros Defender Technical Discussions 15 December 21st, 2008 12:18 PM
Coolant Leak - Help! mlw911 Defender Technical Discussions 6 March 15th, 2006 11:08 AM
Coolant hose leak - cure in a can question michael15 Defender Technical Discussions 3 May 21st, 2005 11:36 PM
coolant leak jperakis Defender Technical Discussions 2 February 27th, 2005 02:39 AM
Small coolant leak near distributor Neo Defender Technical Discussions 4 May 4th, 2004 01:44 PM
