Changed the fuel filter (300tdi) car won't run - Defender Source
Old July 14th, 2012, 08:12 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I've done this many times before with no issues, now the car won't run and barely idles...
I think there is air in the system or something.
ideas?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old July 14th, 2012, 08:15 PM
Should be a straight swap, no concern about air. I've done this at least half dozen times, all I do is pull the old filter, fill new one with ATF, screw on, and start. Even though some say otherwise Tdi is a self bleeding system.
Are you sure you didn't knock some wires or fittings off while you were in there?
Old July 14th, 2012, 08:29 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Don't think so. It was running fine for a few min. Then got very rough and stalled. Won't start now. Doesn't use the regular 300tdi filter. Some other one purolator 50149. A replaceable can that has a 2 part housing
~2008 GTI TSI
Old July 14th, 2012, 08:39 PM
Photo?
Old July 14th, 2012, 09:13 PM
carlosz's Avatar
carlosz
Carlos
Needs to be primed, system has aired due to possible inapropiate filter replacement procedure
the truck ran like a "raped ape"
A fussy warm weather creature...
Old July 14th, 2012, 09:17 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Does your filter housing have a bleed screw?
Land Rover 110
Old July 14th, 2012, 09:43 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Same thing happened on my 90, needed to bleed it well using the bleed screw and the hand pump thing behind the IP. The running fine for a few minutes was it burning off the fuel that was in the lines downstream of the filter.
Old July 14th, 2012, 10:05 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
No leaks as far as I can see. It just won't fire up. Seems starved for fuel or something. I'm going to take the filter assembly apart tomorrow and reassemble. Maybe I missed something. One of the problems with this kind is that you can't actually fill it up with atf, etc then screw it on without getting it everywhere due to the bottom joint. The bolt that goes through it holds the filter to the top and bottom part of the housing. Filling the filter itself is moot unless you can arrange and tighten that bolt it about a quarter of a second...
~2008 GTI TSI
Old July 14th, 2012, 10:23 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
anybody know on that housing where the bleed screw is? also, care to walk me through manually pumping the fuel on the injector pump?
~2008 GTI TSI
Old July 14th, 2012, 11:34 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
That's a tiny filter. Swap it out for a Stanadyne FM100.
Old July 15th, 2012, 05:00 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Even if there's no bleed "screw" on the filter housing, you can still bleed it; just undo the pipe on the outlet of the housing, or on the end of the pipe on the FIP. either crank it over or use the lever on the mechaincal lift pump until fuel squirts out.
Old July 15th, 2012, 08:43 AM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
that looks like a non standard isuzu/ford filter housing - the black plastic cap over the diaphram housing it should be depressed repeatedly to bleed it, there should also be a lever on the bottom of the lift pump to bleed a standard system.
regards all
Gren
Old July 15th, 2012, 10:10 AM
If the lift pump is working and the fuel lines plumbed properly....then it should self bleed without any trouble.
Either the lift pump is dead, easy to check... There is a leak on the suction side... Or it is plumbed incorrectly..
Old July 15th, 2012, 11:26 AM
not sure what filter head that is but its not a tdi one. I'd ditch it.
Old July 15th, 2012, 11:33 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
All is well. thanks for everybody's help.
turns out that circle thing on top of the filter housing is a bleed pump... I took it apart, made sure it was seated in teh o-rings properly, reinstalled, pumped it 10 times and it fired right up.
I'm definitely changing the housing to a screw-on type though. Maybe using one of these kits? -> http://abcprecision.com/
~2008 GTI TSI
Old July 15th, 2012, 11:51 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
The Stanadyne FM100 is also a really great filter. Affordable and their filters come in a variety of grades all the way down to 2 micron which is what I run. They also have optional water separator attachments, fuel filter heater attachments (great for bio) and filter indicators.
Old July 15th, 2012, 12:59 PM
And it bolts straight to the stock location.
Old July 15th, 2012, 01:47 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Originally Posted by Manimal View Post
The Stanadyne FM100 is also a really great filter. Affordable and their filters come in a variety of grades all the way down to .2 micron which is what I run. They also have optional water separator attachments, fuel filter heater attachments (great for bio) and filter indicators.
Will look into this thanks. I might be interested in a dual setup filtering to 30 micron, then 2 or 5 micron (yes overkill, I'm aware). Who knows maybe if I'm swapping it out I can add a heated element or something too.
~2008 GTI TSI
Old July 15th, 2012, 02:56 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Planning on it, I'm looking into other options now. Vendors recommendations welcome!
~2008 GTI TSI
Old July 15th, 2012, 03:24 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Do you have a sedimentor? I was considering replacing the sedimentor with a 150 micron pre filter and a water separator in the sedimentor location then have a final 2 micron filter in the stock location. Like you said it might be a little overkill unless your are overlanding in countries with really crappy diesel. Also I would worry a bit about the the flow and if it would strain the pumps excessively? Anyone here run two fuel filters?
300tdi, fuel, tdi
In-line Fuel Filter Recommendation usadventureracing Defender Technical Discussions 4 March 7th, 2012 11:14 AM
Fuel filter banjo bolts and fittings El Solis Defender Technical Discussions 9 March 5th, 2012 12:11 AM
Inline fuel filter with diesel? JimC Defender Technical Discussions 36 August 29th, 2009 11:15 AM
Calling all diesel guys - Biodiesel??? cbass Defender Technical Discussions 47 January 31st, 2006 11:18 AM
Fuel Filter milli Defender Technical Discussions 3 January 21st, 2005 10:46 AM
