Changed head gasket now TDI wont start - Defender Source
Old April 3rd, 2015, 12:25 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
I loosened the unions at the injectors and I'm getting diesel there, is it possible there is still air in the injector pump? It turns over quickly with a pause every few seconds, which sounds a little odd. Any ideas appreciated.
Old April 3rd, 2015, 04:23 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Shouldn't be air in the pump if you're getting it up at the injectors.
If you just did a head job then the timing should be correct.... you did refit the pushrods didn't ya??
check the valve clearance, but the engine should still attempt to try to start even if they were a little out.
Old April 3rd, 2015, 06:46 AM
vtrover
1991 RRC 300 tdi
I had a similar thing happen, I didn't have the valves adjusted properly, by the time I figured it out I had completely flooded it, I left it alone for a day and it started right up..
Old April 3rd, 2015, 07:15 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
I agree. Check valve adjustment. If it's getting fuel it should kick right off and run rough for a few seconds then smooth out.
Legend in My Own Mind.
Old April 3rd, 2015, 07:16 AM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Jim, i knew i was forgetting something.... Lol . I adjusted the valves and then checked them a second time, but it's not hard to check again. This engine has always started first time so I was surprised to have any trouble at all.
Old April 3rd, 2015, 07:20 AM
Brewie212's Avatar
Brewie212
Brian Kandefer
Did you unplug the fuel cutoff valve under the injector pump by any chance? Single white wire under the injector pump if I recall? That would cause it not to start but not the intermittent pausing...
Old April 3rd, 2015, 07:27 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
The pause could be from a valve adjusted too tight
Old April 3rd, 2015, 09:13 AM
Everytime I've done it, it always takes a while to get the juice flowing. Takes several iterations of starting attempts (let that starter cool) and just before it starts it seems like the engine is about to self destruct, shaking violently.
Mark Kellgren
KM4BOR
Old April 3rd, 2015, 11:06 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Another reason to have a self bleeding fuel system.
Tank, sedimenter, 12V diesel fuel pump, lift pump, fuel filter, IP, return line back to tank.
Key on = Air purged = engine starts right away.
Not a good idea to crank a dry IP if the injector lines were removed.
Valve adjustment is paramount and should have been a mandatory step in the process just after the multiple head bolt degree torquings were finished.
RDavisinVA
Old April 3rd, 2015, 03:18 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Yes, as stated I adjusted the valves and then checked them again during the process of putting it back together. Went home at lunch and bled the pump and the lines to the injector again, removed the head cover and check valve adjustment again (all were spot on) and then tried again. Took a few seconds but then started up in manner similar to what Mark described. Once started it smoothed out and sounds good. Thanks for the advice all.
Old April 3rd, 2015, 03:29 PM
Rob, my comments were always after bleeding the lines. Never tried it dry without a prime. That would just be a waste of time.
Mark Kellgren
KM4BOR
Changed valley pan gasket -now coolant leak Blreid90 Defender Technical Discussions 14 April 21st, 2014 09:33 PM
Changed Thermostat now coolant leak 97-D90-736 Defender Technical Discussions 3 January 3rd, 2010 11:09 PM
Just did an engine swap and now wont run... RyanB16 Defender Technical Discussions 16 March 4th, 2009 11:29 AM
Looks like my 300 TDi head gasket blew again cdb Defender Technical Discussions 6 July 2nd, 2008 08:27 PM
changed cam, all gaskets and now it won't run vesparover Defender Technical Discussions 4 July 24th, 2005 09:56 PM
