Champion Spark Plugs - Defender Source
Old June 6th, 2008, 11:24 PM
JimKo
Jim Kochenderfer
1994 D90
I looked up the required spark plug on the Champion Spark Plug website and got a number of RN11YC4 (322). Then checked the owner's manual and the shop manual and got a number of RN9YC (415). The plugs in my '94 D90 with stock 3.9 look to be original (70,000 miles) and they are RN11YCC. I'm all checked out on what the numbers and letters stand for so I know that the 11's are two heat ranges higher (hotter) then the 9's, otherwise, the plugs are identical. I pulled out four of the plugs and they show no signs of running hot. So what gives, what am I missing and which Champion should I be using, or am I obsessing over nothing (yeah, like that's never happened before).
Old June 7th, 2008, 10:26 AM
I would go with the factory recomended ones. I do not think it will matter much one way or the other.
Old June 9th, 2008, 03:48 PM
Troys
Troy Smith
1995 D90 SW
Champion Truck Plug 4404
Pulstar Spark Plugs cellulararrest Defender Technical Discussions 0 March 17th, 2008 09:51 AM
Which spark plugs? Hammertime Defender Technical Discussions 2 January 30th, 2008 10:15 PM
New spark plugs and wire problem ini88 Defender Technical Discussions 1 December 22nd, 2007 10:56 PM
While changing spark plugs mdmccallum Defender Technical Discussions 9 November 2nd, 2005 09:12 AM
Spark plugs for a supercharged 4.0.. Tom Fitzgerald Defender Technical Discussions 0 May 10th, 2004 11:43 PM
