Center Diff Locked will not Unlock! - Defender Source
Old May 6th, 2009, 10:35 PM
Hammertime's Avatar
Hammertime
Dana Hammersley
1997 Arles Blue #162
My center Diff will not unlock. the linkage is tight {meaning no slop}the shifter moves fine left and right, light goes on and off but when turning on hard surfaces the tires push and scuff more than normal. When backing and turning there is a small clunk and resistance. Also tried the thing where you jack up one of the front tire and try to rotate it. and it will not rotate withthe diff lock not locked. Any suggestions on how to unload unwind or what ever you do to release them?
Old May 6th, 2009, 11:31 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
no idea how to release it but if you are stuck driving it on the road I would say to take one of your driveshafs off for now.
Old May 7th, 2009, 03:16 AM
discoinjapan's Avatar
discoinjapan
Michael Bruzga
93 D1/ 94 D90 ST/96 D1
Try this:
Get on a flat straight road, put your truck in reverse, go back slowly without hitting the brake put the gear in neutral and then try to put it in Hi while its still rolling back. It has worked for me a couple of times.
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
center diff lock light bjf Defender Technical Discussions 16 June 25th, 2016 07:06 PM
HELP!! Center Diff Acting wierd? sorry so long Hammertime Defender Technical Discussions 3 April 25th, 2009 10:32 PM
Center Diff Thrust Washers Paul Grant Wanted 2 December 21st, 2005 08:14 AM
How to troubleshoot my central different locker? MonLand Defender Technical Discussions 7 July 5th, 2005 10:57 PM
