center diff lock light - Defender Source
Old August 21st, 2009, 12:57 AM
bjf's Avatar
bjf
barry f
94 ST #395
I am driving home tonight and my diff lock light starts to flicker and all of a sudden turns on. No clue why. I pulled over and looked to make sure the lever wasn't out of wack. Nothing seems wrong. I then played with it and switched it from side to side and drove a few feet with the transfer case in low then back to high. Leverl is down and to the right. I tried reversing. Nothing.
Any ideas?
Old August 21st, 2009, 01:18 AM
lynchee's Avatar
lynchee
Dennis Lynch
94 D90 #699
Gremlins.....................get me all the time.
They will go away
Old August 21st, 2009, 01:38 AM
bjf's Avatar
bjf
barry f
94 ST #395
How do I test it and is this common? Can I drive it this way?
Old August 21st, 2009, 02:02 AM
see the email I sent you. before driving you need to be 100% sure it is not partially locked. I saw this about 3 or 4 times where it was partially locked and would "catch" and blow up the diff.
Old August 21st, 2009, 02:15 AM
The problem is that it could be partially engaged and could pop into lock and destroy the diff in the t-case.
Old August 21st, 2009, 10:56 AM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
The wire might be grounding somewhere between the cluster and the T-case and making the light turn on. That might be worth looking at.
Pat
Kirk Lazarus, Tropic Thunder
Old August 21st, 2009, 01:03 PM
bjf's Avatar
bjf
barry f
94 ST #395
I think it is the light or the sensor. Truck is driving fine and I engaged the lock and disengaged it and everything works fine.
Annoying
Old August 22nd, 2009, 01:10 AM
bjf's Avatar
bjf
barry f
94 ST #395
It was a loose wire. All is well again until my next post.
Old May 5th, 2012, 03:20 PM
I found some mud this morning and locked the center up. My diff lock light did not illuminate, in the past it would take a few revolutions to illuminate. The center is unlocking and locking as it should. Two things I noticed, the parking brake light doesnt illuminate when I pull the handle up but will light up when I start the truck. Also, the t-case shifter is rather loose.
Do the diff lock and parking brake share a circuit or is it coincidental?
Old May 5th, 2012, 05:14 PM
Swapped switch light works, brake light working as well.
Old May 7th, 2012, 11:28 PM
Sounds like your good, but for the archives: The parking brake and diff lock lights are separate circuits. What they have in common is that each switch can be adjusted, and often when the aren't working, a simple adjustment of the switch is all that is needed.
-Jeff
Is said switch on the top of the tcase? And how do you "adjust"?
Old May 8th, 2012, 12:24 AM
On my disco lt230 it is directly behind the rhs footwell. You must remove the floor panel to access it (removing the center tunnel helps also)
On my switch, adjustment is just a matter of threading the switch in or out - similar to the brake lights
Old May 8th, 2012, 12:28 AM
Raz's Avatar
Raz
Leif
1994 90 ST #1589
Yeah, transmission tunnel or access under the cubby box in the Defender. I'm going to change mine out as mine isn't shifting into lock and I suspect the switch is gummed up and stuck down not allowing the diff to lock. I'll also have better access to the the linkage too if that ends up being the problem.
Old May 8th, 2012, 05:57 AM
winn442's Avatar
winn442
Winn Bearden
Also for the archives, unlike the NAS and older trucks that use the switch on the T/C to complete a ground for the diff lock light, the TD5 trucks feed the switch hot (+12v).
Winn Bearden
Old June 25th, 2016, 03:06 PM
Is this switch part number PRC2911 for an LT230??
Old June 25th, 2016, 06:47 PM
Allbrit MG ROVER & Mini Classic Teilekataloge You can look it up here. -Jeff
thanks
google translate time
Old June 25th, 2016, 07:06 PM
Thanks again Jeff ! - part number confirmed
#22 (PRC2911 switch - high/low) / front output shaft / lt230 / transfer box / defender 1987-2006
ht
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Diff Lock Light Wiring for 83-89 -- Modern T Case Switch Answered SafariHP Defender Technical Discussions 0 September 3rd, 2009 12:36 PM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
diff lock light phunter Defender Technical Discussions 2 August 7th, 2008 11:31 PM
Center Diff Thrust Washers Paul Grant Wanted 2 December 21st, 2005 08:14 AM
