Center Diff Lock Issues (on, off, or in-between) - Defender Source
Old January 6th, 2006, 12:25 AM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Question Center Diff Lock Issues (on, off, or in-between)
My diff lock goes on and off when the lever is pressed over to the left in high or low range.
I think the light is correct when it goes on and off. Does the light work off of the linkage, or the actual diff lock?
Assuming the center diff lock does not work...
Could it be the linkage is worn out?
Could it be the actual center diff lock?
I really don't know how it works.
I just put an ARB in my rear so I am itching to use it.
I saw some stuff about spraying the linkage with lube and working it...
I already tried that...
That linkage looks like a very weak setup to begin with.
Does it work off of an electronic actuator or what?
I have no clue on where to start.
Thanks in advance for any help!
I have to make due with this t-case until I can get a replacement.
-Heath
Old January 6th, 2006, 01:13 AM
Scott 9835
Scott Falter
95 D90
The light works off the diff lock when it engages it press on a switch. If the light works the dif lock is engaged.
Old January 6th, 2006, 09:54 AM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
The actual diff lock mechanism inside the transfercase is pretty robust. The switch for the light is actuated off of the shift fork inside the t-box. it is a spring loaded mechanism, so you can throw the lever and if the teeth arent lined up, the mechanism will spring load and then drop in when the teeth do line up. The light will come on at that point. Same thing when you disengage it. The mechanism will spring load if there is any driveline wind up holding it in place and then release as soon as it can. So the light activation and deactivation is not always immediate when moving the lever. If your light is flickering at random when engaged I would be looking for dirty switch contacts or maybe a bad bulb or a loose electrical connection. You can test diff lock operation by applying the park brake and leaving the transmission in neutral and jacking up one front wheel. With the diff lock disengaged you will be able to turn the wheel, with it engaged you will not be able to turn the wheel. You can call me at the shop later if you need more specific details.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 6th, 2006, 09:55 AM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Well then... I guess my problem is that my center diff lock won't stay on.
The lever wants to move right it seems, but even when I hold it to the left the light goes off (low and high).
Any suggestions on how to fix this?
I just got my ARB in the rear (which works great) and I can't try it out without the center locked.
Rob, I had not seen your post when I wrote that...
I think the diff lock starts on and comes off.
It doesn't really go back on until I push the lever over to the left.
It did work for the test, it just pops out I think.
It is not flickering at random.
It is more of an on then off thing... then I press the lever left again, then it comes on for 5 to 30 seconds sometimes a min.
Thanks very much,
I'm going to jack up the back real fast... actually the front.
Old January 6th, 2006, 01:04 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
I did the test and here is the outcome...
The problem is the linkage.
The transfer shift from right to left only moves the linkage 20% of the full distance...
I put a prybar on the lower linkage and pushed it manually (while my father sat in the truck and moved the lever all the way to the left). It had about 80% of the distance left to go into "diff locked" status.
Once I did this we tested the truck off the road and everything stayed locked. My rear ARB locker worked like a dream, spinning both rear wheels in unison on the soft mud.
Now to figure out how to fix the linkage.
Is there anything that wears out easily that is a common fix?
Old January 6th, 2006, 01:38 PM
Roadsiderob
Robert Dassler
1994 D90
Well,
there are some plastic bushings in the linkage that can wear, the linkage itself can wear, it may be out of adjustment. I'd take a real close look at it and see where the looseness is. Take the rubber gaiter off of the transmission tunnel and remove the foam surroud for a good view of all of the linkage.
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old January 7th, 2006, 06:28 PM
Heath's Avatar
Heath
Heath Ahrens
1995/D-90
Thanks for the advice Rob!
I took off the hump and tweeked the pivot point on the linkage and now everything is working!!!
It was just a sloppy linkage after all.
Thanks so much for your help.
Old November 25th, 2013, 05:57 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
I know this is an old thread but I'm going to ressurrect it because I'm having this same issue (CDL lever on t-case not fully engaging via the CDL shifter), but getting to the pivot point adjustment from underneath is a real bitch. I'm going to try to adjust it (looks like it's a 13mm nut) from inside the cab tomorrow by removing the shift boot and foam. But I also want to grease the CDL linkage. What kind of grease works best to lube the linkage mechanism and lever on the t-case?
Old November 26th, 2013, 09:44 AM
Mamba's Avatar
Mamba
Richard
'65 109 Dormobile
I recently swapped out transfer cases and found that my "engaged" light would not stay on. After some comparison of the two cases, I found that the square metal cover over the top of the cases (fits over the hi/lo/dif loc shifter) were slightly different. The dif loc slot sas slightly shorter on the new transfer case cover, and it simply would not let the gearshift lever move all the way over to fully engage the dif loc. I swapped out the covers to solve the problem.
By pulling the rubber tunnel cover you should be able to see the piece I am talking about. Try taking the metal limiter cover off and see if the shifter moves more convincingly into the locked position. A little filing of the slot may solve your problem. Have absolutely no idea why those parts were different.
Old November 26th, 2013, 10:47 AM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
Thanks for the info. I lubricated the linkages and adjusted the pivot point a bit from underneath and it seems to be working correctly now. I don't think my truck was offroaded much if at all by the 2 previous owners so the CDL probably didn't get much use.
I spoke to another D90 owner who had his apart on a bench and he said that the lever doesn't need to turn all the way on the t-case in order to engage the diff lock because the lever just applies pressure to a spring-loaded pin when shifted. Once the gears line up properly the pin then pops into gear to lock the diffs.
'95 RRC LWB Aspen Silver
'86 110 SW Conniston Green - SOLD
'95 D90 ST Beluga Black - SOLD
'96 D1 SE7 Willow Green - SOLD
Old October 29th, 2017, 01:39 AM
DiscoDavis
C Davis
1990 110, 1995 Disco
Reviving this old thread. Just wanted to point out I had the exact same issue. The lever travel was physically limited by the smaller opening bottom plate he describes. Looked at manuals and diagrams and everything shows matching large openings, so I removed the plate completely and will put it back once it has been cut.
Reason I went hunting is my diff lock lever would engage the diff, but pop out of lock at the worst time. On tough bits I had someone hold it left. If I can get pics I will pop them up
center diff lock light bjf Defender Technical Discussions 16 June 25th, 2016 07:06 PM
Diff Lock Remains Engaged but Light is Off - Whats Wrong? R. Kurk Defender Technical Discussions 14 April 5th, 2009 12:01 AM
4 Wheel / Diff Lock hamiamham Defender Technical Discussions 4 August 7th, 2007 08:50 PM
Overheating/ Diff Lock question icurnmedic Defender Technical Discussions 14 June 27th, 2006 06:06 PM
Center Diff Thrust Washers Paul Grant Wanted 2 December 21st, 2005 08:14 AM
