Center dash electrical gremlins - Defender Source
Old December 6th, 2009, 06:21 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
I am pulling my hair out in attempt to find out why when I hook up a clock, volt meter gauge or anything else for that matter it works fine until I turn the headlights on? I am using the wiring that comes up at the center of the dash above the fuse panel, not the instrument binnacle. Does not matter if I choose a positive lead that is live all the time or only when the ignition is on such at with the volt meter. There are a ton of wires to choose from but it all turns out the same, loss of power when the headlights turn on. What gives?
Old December 6th, 2009, 06:23 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Full loss of power or just a reduction in volts?
Old December 6th, 2009, 06:34 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
Full loss, test light turns off, when headlight turns on. Volt meter is reading 13.5 when truck is running with headlights on, it just seems to be the wiring in the center console area where the 12 accessory plug or cigar lighter are.
Old December 6th, 2009, 06:44 PM
D90user's Avatar
D90user
steve
Wierd. Only thing to do is to trace it back.
Long ago I started my own accessory fuse panel, you may want to do this also. It really makes life simpler.
sorry I dont have better advise.
Old December 6th, 2009, 07:48 PM
has someone wired in a relay to power over wattage bulbs?
My guess and it's only a guess that the lights being off provide an earth route for all the accessory lines and when it powers up it changes the earth path.
did it ever work? did it just start to fail? what did you do between working and fail?
Old December 7th, 2009, 07:53 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
What kind of shape is the light switch in? They do start to melt internally sometimes, and that causes all sorts of oddball problems as all the connectors move around in the goo of melting/solidifying plastic.
-Hans
My oil line fix
My 100k stopped odometer fix
Old December 8th, 2009, 01:37 AM
kellymoe's Avatar
kellymoe
kevin
defender 130
-Hans
Hans,
That might be it, other switches such as the highbeam switch has started giving problems. I think it's time to just replace all the steering column switches.
dash, electrical
MTC4618LOY Center Dash Trim 90/110 FS SafariHP The Vendors Loft 4 October 13th, 2015 08:40 AM
Need a center dash switch holder Uncle Douglas Wanted 3 September 27th, 2012 06:40 PM
HELP! Indicators, Dash, Electrical Problems minorthreat Defender Technical Discussions 3 April 11th, 2007 09:19 PM
Center Dash Fascia for Gauges Hoss Wanted 15 March 3rd, 2006 03:58 AM
Blank Stainless Center Dash Panel (bling) JimC For Sale - Parts 0 November 18th, 2004 03:56 PM
