CEL light when idling - Defender Source
Old May 6th, 2010, 01:19 PM
does anyone have any input on this.
I get a check engine light when i idle for say 5-10 minutes (stationary, say when i'm on the phone etc.)
it glows a steady red and does not blick, i have not had the chance to see if there are any codes showing when it does this.
Pulling power for 30 seconds clears it and it does not reappear until i idle again.
O2 sensors maybe on thier way out? something else.
doesn't seem to be something that i need to worry about other than my OCD for things working right.
the engine is stock 3.9 gas, with stock exhaust and Cats (97K miles) just did a recent (~2k miles ago) large service with no issues, no leaks except for 1-2 drops every few days from the Rear Main seal (engine to tranny junction)
95' D90 - daily driver..
Old May 6th, 2010, 02:12 PM
What code does it throw on the code reader. It is the little black box under the PS seat.
Old May 8th, 2010, 12:36 PM
It is a code 44
o2?
Old May 8th, 2010, 01:53 PM
Yup.
http://www.robisonservice.com/servic...er_trouble.asp
Make sure you don't have a vacuum leak or something, but in my experience if the O2s are original, they have just gone bad. Buy a pair of new OEM from roverguy.com (and tell Will I said hi).
Ron
Old May 8th, 2010, 02:33 PM
Check just ordered a set from ab before I saw your post
Old May 8th, 2010, 05:45 PM
Those are fine too and AB is a good vendor, Eric is great and supports the community, and has a good price (just $15 a pop more than Will is all).
Ron
Old May 14th, 2010, 12:45 PM
thought i would update everyone (who cares anyway)
Ordered the 2 lamda sensors from AB ~220 shipped with express 2 day freight.
Install is simple and straight forward took about 30 minutes for both due to a zip tie that I put in earlier when i did hte winch wiring. Other wise should only take 20 minutes or so as long as your old ones come out neatly (i.e. you did use anti-seize right? you need to).
The new ones from AB came precoated with high temp anti seize as well. so unscrew, cut the 2-3 zip ties and unplug the old ones and reverse for the new ones.
Verdict: huge improvement in drivability and smoothness, My gas mileage seems to have increased as well but the verdict is out on that until i run this tank out and track the next one. (was apx ~170 miles to 14.5 gal prior to this, about 11.7 mpg in other words), this seems to indicate a rich condition existed due to the lamda (O2) sensors).
I am speculating that i might pick up 2-3 mpg from the new sensors - but that is pure speculation at this point until i can track it accuratly.
the truck runs better than ever (knock on wood!!)
thanks for the help.
Old May 14th, 2010, 12:59 PM
Glad it seemed to work out.
Ron
cel, check engine light, ht
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
Intreior Light Problem proulx70 Defender Technical Discussions 3 February 7th, 2007 05:30 PM
Light disaster! rustydefender Defender Technical Discussions 11 December 30th, 2005 03:34 PM
Rear Dome Light Stays On thug1313 Defender Technical Discussions 5 November 1st, 2004 08:33 AM
Check engine light / Rough Road mhansen Defender Technical Discussions 16 June 9th, 2004 01:14 PM
