CDL not locking - Defender Source
Old May 2nd, 2010, 03:24 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
CDL not locking
I have had this problem for a long time now. Since the current transmission was installed. The CDL lever doesn't shift the linkage enough to lock the diff. My question is hot to fix this? I'd actually like to be able to lock the thing without having to dive under the truck like I do now. The lever does unlock it and works as far as hi low in both locked and unlocked.
Jimmy Buffett
Old May 3rd, 2010, 11:27 AM
What's different about this transmission? Have you looked to see if it's binding somewhere? Pulled the boots and made sure they are not restricting access?
Old May 3rd, 2010, 12:21 PM
linkage is adjustable. pull the boot and tunnel cover. there is a fulcrum bolt that threads into the side of the r380 that is adjustable by threading it in or out to increse or decrease throw
Old May 3rd, 2010, 01:30 PM
flippedrover
Tyler
'94 D-90
Nothing as far as I know is different. Its just never worked. I'll pull the boot and cover and play with the link. Thanks for the help.
Jimmy Buffett
Old May 11th, 2010, 12:58 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
Little old, but here are some photos and a video on how to fix it.
http://www.landroverexpedition.com/t...-lock-linkage/
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old May 12th, 2010, 08:13 AM
flippedrover
Tyler
'94 D-90
O thanks. haven't tackled this yet but that makes a lot of sense.
Jimmy Buffett
Old May 12th, 2010, 02:06 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
it is worth checking if it is not locking or the light is not working, before you try to adjust it.
Old May 12th, 2010, 07:49 PM
hutch's Avatar
hutch
Hutch
97 AA Yellow D90 ST
I'm having the same issue on my 1997 D90. I don't think the previous owner ever did and it's frozen. I don't want to push to hard and risk bending it. I've taken the boot off but removing the center console cover looks a bit hairy. Any pointers at getting at it without doing that? Or if not, how to remove the console cover without ripping apart the interior?
Old May 13th, 2010, 08:05 AM
flippedrover
Tyler
'94 D-90
I know its not moving enough because I have to crawl under the truck to get it to move that last little bit.
Jimmy Buffett
cd
ARB Locking Diff. michael15 Defender Technical Discussions 3 December 17th, 2005 11:29 AM
OEM locking lug nut kit sheki For Sale - Parts 0 October 2nd, 2004 11:31 PM
CDL woes ToaDisco Defender Technical Discussions 10 September 27th, 2004 06:10 PM
c - locking diff problem simmojr Defender Technical Discussions 11 September 15th, 2004 09:25 AM
Rear door remote locking Ray Defender Technical Discussions 3 November 23rd, 2003 11:50 AM
