CB Antenna Mounting - Page 2 - Defender Source
Old February 23rd, 2010, 01:08 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Looking at tha mount I would worry about strength. What I was thinking was a good solid clamp then something like a series windshield hinge with a cross-pin hole for up and one for down along with a clip for the antenna near the top for keeping it from vibrating against the rack when folded. The have quite a load on them in the wind and a spring mount is still needed to make sure you do not shear it off on something, ideally nothing unsprung would extend above the top bar of the rack or you know you will find a tree branch and break it.
I also forgot to mention that the above "screening" by the vehicle is why truckers mount one on each side of the cab.
Another option is a 3x wave whip, I may end up needing something like this for the shortwave when using it for data/basecamp duties, you attach one end at the front wing and bend it back. Of course if you go MOD FFR you could also use radio boxes
Old February 23rd, 2010, 03:22 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
That's phasing... They feed two antennas in phase to provide gain (directivity) front and back. Doing that can net you up to 3db if they're setup optimally.
Old February 23rd, 2010, 03:37 PM
phoenix37's Avatar
phoenix37
john
Originally Posted by cellulararrest View Post
Just remember... All you have to do to ground an antenna adequately on a vehicle is attach the coax shield to the body/frame. It's not an involved process and will yield better results. Don't be afraid of it.
What is a coax shield and how do you attach it to the frame? Ive got my antenna mounted to the tire carrier which doesnt seem to be properly grounded.
Old February 23rd, 2010, 03:42 PM
cellulararrest
Chris Snyder
Coax shield is the braid that is the outermost conductor inside the cable. So it goes, from the center: center conductor, dialectric (usually that thick plastic stuff), shield (braid), then outside insulation.
Depending on what mount you're using, the mount itself is probably connected to the shield.
Do you have a picture of your mount?
Old February 23rd, 2010, 05:22 PM
phoenix37's Avatar
phoenix37
john
Here is a pic.
Old February 23rd, 2010, 05:33 PM
cellulararrest
Chris Snyder
If you take the connector off the bottom of that mount, you'll see that there are two conductors. There's the middle conductor, and then the outer conductor (the threads).
That outer conductor needs to go to ground (your tire carrier). The center conductor needs to go to your antenna.
Make sure that the center conductor passes through the hole you drilled and is insulated from your tire carrier by those nylon washers. It can't touch the sides of the hole (the hole needs to be wide enough) otherwise you'll have a short and end up destroying your radio and not being heard.
If you have a multi-meter, you can test and see if your mount is right by checking continuity between the outer portion of the coax (while connected to your mount) and your frame.
Then to make sure you don't have a short between the shield and the center conductor, make sure there is NO continuity between the top of the mount and your frame.
------ Follow up post added February 23rd, 2010 05:35 PM ------
Or, at the radio end of the coax just make sure there's no continuity between the inner and outer conductor. (this is all assuming that you don't have a no ground plane setup)
Old February 23rd, 2010, 05:41 PM
phoenix37's Avatar
phoenix37
john
Got it. Thanks Chris.
Old February 23rd, 2010, 05:42 PM
cellulararrest
Chris Snyder
Hopefully that made sense. Hard to describe without actually showing you!
Old February 23rd, 2010, 05:47 PM
phoenix37's Avatar
phoenix37
john
I understand what part needs to be grounded now so ill just try and make that happen. the local 4x4 shop said my tire carrier wouldnt work as a ground and I need to run a ground from the mount to the frame.
Old February 23rd, 2010, 05:49 PM
cellulararrest
Chris Snyder
Well it's an easy check with a multi-meter. Mine was connected fine. If you want it to be perfect, you'd run grounding straps between all the body panels, but that's a bit excessive for just trail communications...
------ Follow up post added February 23rd, 2010 06:09 PM ------
I doubt anyone does, but if you want to read about bonding... http://www.k0bg.com/bonding.html
For whatever reason, a lot of CB shops have some weird ideas about all this stuff.
Old February 23rd, 2010, 06:44 PM
phoenix37's Avatar
phoenix37
john
Thanks again Chris and yes it would be just for trail communications. I used an FRS radio for the first time on the trail this weekend and the range was terrible. I thought if was really stuck out here with just this walkie talkie id be screwed.
Old March 4th, 2010, 12:50 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I just ordered a CB. What kind of antenna should I get? AM/FM? HF? VHF/UHF? Is there such a thing as a CB specific antenna?
Old March 4th, 2010, 10:05 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
11 meters so i think it's HF.
- Charles Eames
Old March 4th, 2010, 10:15 PM
Rugbier's Avatar
Rugbier
Gustavo
Firestick NGP, mount it in any surface you want.
my old 90 had an anodized bracket mounted on the Tire Carrier and the antenal mount bolted to it.
Maybe Chirs Bird will post a pic ( I can't find one ), but available a Quadratec under roll cage mounts
NO SIGNATURE
Old March 5th, 2010, 01:12 PM
I have the Firestik side mount on the back. 7 year and lots of abuse. No problems.
http://www.firestik.com/Catalog/MK-M2.htm
Old March 6th, 2010, 03:30 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Firestik it is.
Another CB-newbie question. Is there a way to hook the CB up to external (dash or door) speakers or do you guys only rely on the built in cb speaker?
Old March 6th, 2010, 07:35 PM
It depends on the CB, but many have external speaker outputs.
mount
Ghetto-Gardô CB Antenna Mount Ren Ching Smaller Projects 13 August 6th, 2009 03:29 PM
Mounting a CB antenna on a 1997 D90 SW? pmd Defender Technical Discussions 13 January 11th, 2007 11:47 PM
CB Antenna Splitter bjenk Defender Technical Discussions 2 March 28th, 2005 08:45 AM
Antenna Wanted For 95 D90 Rockhead12 Wanted 2 January 12th, 2005 06:12 PM
CB mounting ideas flippedrover Defender Technical Discussions 21 March 29th, 2004 11:22 PM
