CB Antenna Mount - Defender Source
Old November 21st, 2007, 03:59 PM
Joe Cole
Joe Cole
97 D-90
CB Antenna Mount
I did a search but did not find anything on where and how to mount a the antenna specifcally on a D-90 ST.
Any picture would be appreciated.
Joe
1997 D-90
1997 XD
1999 DII
1999 DI
Old November 21st, 2007, 04:08 PM
JimKo
Jim Kochenderfer
1994 D90
CB antenna mount
I bought a bracket from Shawn on this site (Muddy Oval). It was a copy of the old SG mount and it worked great. Check the "Parts For Sale" section and look for a thread titled "Safari Guard rear worklight bracket w/ cb mount hole." I don't know if Shawn has any brackets left, but it's a high quality piece and in the posts there are links to photos and a Safari Guard instruction sheet. One of these days I'll get a picture of the installed product and get it posted.
Old November 21st, 2007, 04:38 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Take two pieces of 1/8" thick mild steel. (3" wide piece of strap from Lowe's or Home Depot.) Cut to about 4 to 5" long and weld at right angle to each other. Cut holes to match those holding the license plate light on one surface. Cut another 4" to 5" piece to go on the inside of the tub as a backing plate. Grind to look beautiful and paint. Takes about an hour. I have a little Eastwood powdercoater I use as the final step, but bottom line it is one of the easiest fabrication projects you can do on a 90. If you got some scrap metal it's zero cost. Even if you have to buy the strap at Lowe's it probably less than $10. Shoot make them as Christmas gifts for your friends
Old November 21st, 2007, 05:42 PM
I put mine on the top hinge of the st tire carrier... Send me an email and I will attach a picture swold (at) pbcx.com.
Old November 23rd, 2007, 09:06 PM
Here are a few pics of mine
ID:	11139   Click image for larger version
mount
CB Antenna Mounting nycjdp Defender Technical Discussions 36 March 6th, 2010 07:35 PM
ARB CB/HAM Antenna mount - used dmarchand For Sale - Parts 9 December 31st, 2009 12:46 PM
Ghetto-Gardô CB Antenna Mount Ren Ching Smaller Projects 13 August 6th, 2009 03:29 PM
1997 Radio Antenna Removal ronward Defender Technical Discussions 12 August 8th, 2007 08:21 PM
CB Antenna Splitter bjenk Defender Technical Discussions 2 March 28th, 2005 08:45 AM
