CB Antenna - Defender Source
Old January 8th, 2011, 09:12 AM
TexasD-90's Avatar
TexasD-90
Martin Spencer
1994 D-90
CB Antenna
I have a Cobra 75 WX ST and am wanting to make sure I maximize its capabilities. I have searched around and found that the antenna and the way it is grounded seems to be very important. So my question is: What antenna woks best?
That is why it is called a short cut. If it was easy it would just be "the way."
Old January 8th, 2011, 11:48 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Firesticks are very popular with those with CBs.
I don't know about other clubs, but out here in San Diego almost everyone has taken the time to get ham licensed and we use 2 Meter on many trips. Better sound, no interference, and if needed we can use the myriad repeaters around for very long distance.
Old January 9th, 2011, 07:08 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I run a 3' Firestik (the kind without the external ground wire) on my 94 with the same CB. Mounted on a bracket over the license plate light and have had great results in the trails/parks in this area. Assuming that if I were to take the time to actually set it up properly with an SWR meter it would be even better!
Old January 9th, 2011, 08:07 AM
tweak
Darich Runyan
'04 Disco
x2 on the amateur radio license. It is easy to get a Technical rating and you get much better sound and clarity, not to mention the ability to call long distance for assistance.
Old January 9th, 2011, 10:53 AM
DMSLongLake's Avatar
DMSLongLake
Dave Sherwood
1994 D90 ST
I am going to mount an NGP Firestik in the hole for the factory antenna (since I never use the radio...)
DMSLongLake
Current Rovers:
1994 D-90 ST #734
2006 LR3
2016 RRS
Past Rovers:
1997 Disco I
1999 Disco II
1995 D-90 ST #2731
2003 Range Rover HSE
2008 RRS
2013 RRS
CB Antenna Mounting nycjdp Defender Technical Discussions 36 March 6th, 2010 07:35 PM
Ghetto-Gardô CB Antenna Mount Ren Ching Smaller Projects 13 August 6th, 2009 03:29 PM
CB Antenna Splitter bjenk Defender Technical Discussions 2 March 28th, 2005 08:45 AM
Antenna Wanted For 95 D90 Rockhead12 Wanted 2 January 12th, 2005 06:12 PM
Power Radio Antenna Kimos Defender Technical Discussions 0 October 21st, 2004 08:45 PM
