Cat raddles - options please - Defender Source
Old October 18th, 2011, 11:04 PM
my right cat started raddling on my trip to High springs FL from raleigh. I'm assuming it coming apart internally and will need to be either
1. replaced ($ 2,300 from RN)
2. deleted - i don't see any negatives here replacement will be either a custom SS system from a local shop or something off the shelf.
any other options or thoughts? I don't have to worry about emissions any longer so deleting them is not an issue.
95' D90 - daily driver..
Old October 18th, 2011, 11:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
Cut it out and replace
Old October 18th, 2011, 11:38 PM
drsmiley's Avatar
drsmiley
Roger
97 ST
Delete
Old October 19th, 2011, 06:44 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
If you the y-pipe overall is still in good shape just have a local shop install universal cats.
I'm not sure stainless is worth it, as so far my y-pipes have lasted longer than the cats.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 19th, 2011, 09:29 AM
Naplm00
Matthew
yea cheap maganflow universals are readily avail.
I get all my exhaust stuff from http://www.performancepeddler.com/ just give them a ring and let them know the diameter of the in and out.
Ive passed NJ and NY tough emissions inspections on a 96 f150 and numerous E30s with these things equipped
Old October 19th, 2011, 11:13 AM
bjf's Avatar
bjf
barry f
94 ST #395
Doesn't magnaflow now sell a complete y pipe?
Old October 19th, 2011, 12:04 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Yes they do.
I just got a Magnaflow stainless cat-back for my Disco. I was kind of disappointed to see the mating flange on the muffler wasn't also stainless since I didn't see mention of that on their website.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 19th, 2011, 12:10 PM
bjf's Avatar
bjf
barry f
94 ST #395
Could go nrp but I hear the fit is a nightmare and who knows how
Much stainless is in it or what kind.
Old October 19th, 2011, 01:08 PM
$800 for an aftermarket y-pipe.
Old October 19th, 2011, 09:05 PM
On the 4800 Y-pipe is that with cats or just the pipes no cat's ?
Old October 19th, 2011, 10:45 PM
the npr parts are $900 ish - for the y pipe and cats -
good to have that option but i think a custom system may be the way to go - will price it out. the raddle is not bad yet and i've some other items to take care of first but this is up there for my fixes to my DD.
Old October 20th, 2011, 10:35 PM
I drove for a couple of years before messing with mine ... rattle went when it warmed up ... don't mess about getting cats cut out and replaced unless you are really sure the place is competent ... a friend tried this and has spent more than a new y-pipe and it leaks ...
Old October 20th, 2011, 10:53 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
One of mine was rattling on my RRC and I had a competent local guy weld in a new cat and a magnaflow muffler for $300. Problem solved. BTW, the aftermarket cat looks better than OEM. Smaller and an integrated heat shield.
Chance
Bad Cat 97 D-90 any options ? jorge Defender Technical Discussions 5 January 11th, 2009 01:43 PM
Options for replacing '94 D90 CAT PCRover Defender Technical Discussions 2 July 17th, 2008 06:01 PM
exhaust- options Nigel Defender Technical Discussions 11 October 20th, 2004 10:34 PM
Replacement Cat for NRP Roadsiderob Defender Technical Discussions 6 July 24th, 2004 12:55 PM
Cracked Cat - fix? (pic) wicks Defender Technical Discussions 14 May 20th, 2004 12:17 AM
