Castor Corrected Radius Arms - who'se got 'em? - Defender Source
Old August 27th, 2007, 10:16 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Just went to Rovertracks site...they're not shown.
So I'm wondering who in the states is selling them, or if anyone here has some they want to sell, I'm looking for a set.
Thanks!
Michael Slade
www.tawayama.com
Old August 27th, 2007, 11:43 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Rovertracks sells cranked trailing arms, not front radius arms. Rovertym Engineering sells the castor corrected front radius arms. HTH. Mark
Old August 27th, 2007, 11:53 PM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
Alright...so here's the dilemma:
I have a 2-3 inch lift on the RRC. I have the 'squirrely and somewhat vague' steering. I have a DC front driveshaft.
Do I:
1. Get the castor corrected radius arms
2. Get the re-indexed swivel balls
3. Get them both
Hmmmm......
Michael Slade
www.tawayama.com
Old August 28th, 2007, 12:23 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
Do I:
3. Get them both
Hmmmm......
RoverTym says that the re-drilled swivel balls are enough to correct a 2" lift, but I like the idea of replacing the stock radius arms with something beefier.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old August 28th, 2007, 12:38 AM
Oxcart13's Avatar
Oxcart13
Mark M
D110
I'd go with the radius arms - a little cheaper and easier to swap in. This alone may fix your problem, and if it doesn't then go with the swivel balls. Mark
Old August 28th, 2007, 07:36 AM
Andrew Vick
Andrew Vick
95 D90
Do I:
3. Get them both
Hmmmm......
Have you checked all the small stuff? I got that after lifting, then started to replace tie rod ends etc., only to find out the left front hub nuts had backed off allowing for 1/8" play top to bottom. Drove like ass.
Old August 28th, 2007, 09:18 AM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
That is a good point. I can go through the whole front end pretty quickly and find out.
Michael Slade
www.tawayama.com
Old August 28th, 2007, 11:00 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Start with the arms.
JP
I have some teflon coated swivel balls you can send in if you decide you need them later also. At a good price. But I bet the arms will do it for you.
legend in my own mind
Old August 28th, 2007, 12:07 PM
pcscharfe
pcdefender
D90/NAS 110
Stephen Peters has some QT Services 6degree Castor Corrected Arms available.
Here is the "Parts-For Sale" listing
http://www.defendersource.com/forum/...eferrerid=1953
4x4 Adventure Gear also sells the QTs in both 3 and 6 degrees
http://dev1.boomersdomain.com/cgi-bi...ml?id=9pNABmq2
If you want to spend $1350 on a set of Italian designed arms try Equipe/Drakken
http://www.equipe4x4.com/inglese/ART...RAILING%20ARMS
Old August 28th, 2007, 12:12 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
I have Steve's on the Wifes car and a three link on mine, both 3' lift I believe in castor correction after 3".
Steve's (RTE) are the shiznit. We used QT on the "race" disco and bent two of them..
Keith
Big, Red and ... aaa Red..
Old August 28th, 2007, 02:53 PM
pendy's Avatar
pendy
jim pendleton
89'd90
6 degrees is to much. For the radius arms alone. Bad pinion angle.. Better to have 3 degree arms and up to 3 degree balls clocked. IMO.
Steve will request an alignment before clocking balls. Align it with the arms installed and go from there.
JP
Old August 28th, 2007, 03:10 PM
pcscharfe
pcdefender
D90/NAS 110
Correct. QT lists 3 Degrees for 2" lifts and 6 Degrees for 4"+
Old August 28th, 2007, 03:24 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Steve did a set for me at 5 degrees after some protest but he also made them about an inch longer.
Keith
www.rovertracks.com
Buy my stuff!
Keith
Old August 28th, 2007, 06:02 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I've never had my balls clocked. Sounds painful.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old August 28th, 2007, 06:11 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Lmao
Legend in My Own Mind.
Old August 28th, 2007, 06:25 PM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
It's not nearly as bad when you put a soft rag in the jaws of the pipe wrench.
Keith
Old August 28th, 2007, 06:53 PM
Back on topic, how effective are castor corrected arms at restoring the stock feel? Do you also have to replace the front driveshaft?
Old August 29th, 2007, 09:34 AM
Tawayama's Avatar
Tawayama
Michael Slade
No Land Rovers
I'll get on the horn and order me up some bent arms then. Thanks for the input.
Pendy - I have two complete knuckle assemblies here. If I was going to have them clocked I could do it w/out any downime...so I don't really need the teflon coated ones. But they do sound sexy.
Michael Slade
www.tawayama.com
Old August 29th, 2007, 03:36 PM
pendy's Avatar
pendy
jim pendleton
89'd90
I heard you were married now?
Old August 29th, 2007, 03:51 PM
Rod Hayward's Avatar
Rod Hayward
Rod Hayward
95 D90 Green #2288
Originally Posted by pendy
I have teflon coated balls
Dave- Normally that would hurt.
Pendy's always one step ahead of the game!
8-track, gun rack, spittoon, gimbal mounted beer buoy, blah, blah, blah, blah......
Radius arms or trailing arms sflash868 Defender Technical Discussions 12 May 28th, 2006 05:40 PM
Used D90 Radius Arms Northface Wanted 3 March 29th, 2005 08:42 PM
Looking for HD driveshafts, radius arms, and more chrisvonc Wanted 9 October 4th, 2004 05:05 PM
Radius and Trailing arms chrisvonc Defender Technical Discussions 18 June 9th, 2004 10:21 PM
WTB - Caster corrected radius arms Tawayama Wanted 4 February 12th, 2004 12:35 AM
